Black Headlight Modification
scoobyra Aug 20, 2009
  1. scoobyra
    scoobyra It's not f@cking ORANGE!!!!!
    798
    Having done a brief search of the forum and not had much success, does anyone have any info on painting the chrome surround on the inside of my S3 headlights??
  2. TorqueTerrorist
    TorqueTerrorist www.sprayplan.co.uk
    485
    94
    Hello mate.
    You need to carefully remove the clear lens by gently heating up the complete edge as these are bonded on. Once heated it should come apart easily. As for painting the chrome this is not the case. You need to use something like T-cut to remove the chrome coating. This is certainly the case in other cars and I'm sure Audi can't be much different. I'm wanting to do my A4. I'll get round too it soon I'm sure. Let me know how you get on
  3. Davsurfa
    Davsurfa Member
    169
    Surely, if you paint over or remove the chrome background inside your headlights, the beam will be next to useless? Also if it was done would it be an mot failiure?
  4. TorqueTerrorist
    485
    94
    If you look inside most modern headlights they have a few components within. The idea is to make black the outer part to give the smoked look. Obviously the insides differ from car to car but some look really good. I've got xenons so they have the projection lenses so this mod is possible. Not sure whether to yet as not seen my model with it done
  5. Davsurfa
    Davsurfa Member
    169
    I've got a '98 A3 1.6 so I'll have to have a proper mooch at it when I get it back from the surgeon.
  6. boya
    boya Member
    384
    i have done this to corsa b headlights stacks of times, to heat the bonding that holds the glass to the headlight place the light in boiling water, then gently prise them apart after 5 mins or so and place back in water if necessery. the first time i tried it i was told to put them in the oven on a low heat but after sevral headlight lens's and trips to the scrappy i reverted to water and it works a treat!! :o.k:
  7. Davsurfa
    Davsurfa Member
    169
    My lights aren't the projector type. There is however a separate piece around the front of the lamps inside and obviously the piece that separates the two sides of each lamp that I could paint but like TorqueTerrorist said I'd rather see my type of lights done before I leap in and rip mine apart.
  8. TorqueTerrorist
    485
    94
    After, little deliberation, I've decided it's too Chav/boyracer for my Audi! If there is every smoked lights made then possibly but I cannot bring myself to ruin my xenon lamps....It's no corsa b....:kissmyrings:
  9. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    Cover with some Lamine X film which is a lot quicker and easier to do plus if you ever don`t like it just heat the film up and it will peel off.
    DeeGee68 likes this.
  10. TorqueTerrorist
    485
    94
    That crossed my mind. A friend does tints graphics etc
  11. devonmikeyboy
    1,245
    My car with lamin-X on left and normal on right.
  12. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    OOh, I like that!! It makes a lot more difference than I thought it would.
