Black Head Lining
NineNails Jul 19, 2010
  1. NineNails
    NineNails Proud sponsor of the snack food industry
    583
    Was it standard on the 1.8tqs ? I have it and it's lovely, makes the car kinda 'cozy' to be in but someone is telling me it was special order item and not common and I know sod all about the interior colour schemes on these.
    Cheers, Si
  2. aragorn
    17,956
    701
    Standard on the TQS afaik.
    The TQS is a bit of a special edition, kinda like a "mini-S4". Lots of its mechanicals and things are all S4 spec, as is the chassis itself, so it should be a bit more special than the old quattro you had.
  3. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    how do you mean "as is the chassis itself"?
    what chassis upgrades does it get?
  4. aragorn
    17,956
    701
    erm let me think,
    integral upper strut brace
    lower subframe bracing
    alloy top suspension mounts
    Solid track rod ends
    large front CV's and bearings
    cast (rather than pressed steel) rear upper wishbones
    Those are the bits i can think of offhand, theres probably more, and any hidden upgrades such as thicker metals used etc wont really be visible.
    The PR code for the Chassis/Suspension package on a TQS is listed as "Quattro Gmbh"
  5. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    all later v6 and quattro got strut brace, alloy top mounts are fitted from 98 ish on
    do love the dark interior though
  6. aragorn
    17,956
    701
    Oh thats interesting about the brace...
    Looking on ETKA, the only FWD's to get them are the AFB engined models (2.5 tdi)
    Under Quattros, they're listed for S4 and 2.5TDi on prefacelift cars, and dont have any notes against them for facelift models (suggesting its fitted to all of them)
    There is another brace with a different part number listed as "SPORTPAKET QUATTRO GMBH" though, wonder what thats for!
  7. Foxmeister
    Foxmeister Fired Up!
    1,785
    Read somewhere that the 2.8 had strutbrace also, not sure if its true thou, havent checked mine???
  8. aragorn
    17,956
    701
    Well from what i can see on ETKA the only FWD that got it was the 2.5TDi.
    Facelift quattros would appear to all have it, so if your car is a facelift 2.8Q then it should be there.
  9. Foxmeister
    1,785
    Na, mine is a 97, boo! Will look into getting one now thou!
