Black Exhaust Smoke?
Sm[]key Mar 3, 2007
  1. Sm[]key
    Sm[]key New Member
    19
    I have a 1998 Audi 1.9 Tdi with 98000 miles on the clock, at around 2000-2300 rpm the car produces a hell of alot of black smoke. If I then apply full throttle and accelerate it stops smoking?
    At around this rpm the engine is very lumpy, and basically hits a noticable flat spot briefly with acceleration.
    I've used the vag-com diagnostic software on it whilst driving but cant see any problems? :keule:
    I've recently had a new MAF fitted and also the cam belt, pulley, and tensioner fitted, along with a fuel cut-off solenoid.
    Has anyone have any ideas on whats up?
    :hi:
  2. inigoj
    inigoj Member
    263
    What rpm is your boost kicking in?
    Sounds like it is over-fueling / not getting enough air or boost pressure at lower revs.
  3. Sm[]key
    Sm[]key New Member
    19
    I think it kicks in around 2500-3000 rpm in 2nd gear, I will have to check to verify this.
    There's a bit of history with this car:
    I've had a problem with it for some time. I've driven hundreds of miles previous with the turbo boost not kicking in; i.e. the turbo was spinning but I had an 1.9 Tdi with no boost.
    I went to numerous garages and sorted various faults that cropped up on the car but the lack of boost problem kept coming back.
    I ended up losing faith in the garages and decided to do it myself after a seriously deflated wallet. I got hold of a vag usb cable on the cheap and plugged it into my laptop with the correct software and voila!:rockwoot:
    There was the fault.....a problem with the fuel cut off solenoid, I fitted a new one and back came the turbo, as easy as that! Although I now have the problem described above.:think:
    After this event I now have very little faith in the garages I used, including one of the main dealers I used! To be fair I just got sick off paying through the teeth for incompetencey....anyway enough of the rant! :whip:
  4. inigoj
    inigoj Member
    263
    There could be a number of things causing these symptoms.
    If its juddering you are definitely getting to rich a mixture at lower revs.
    Your boost should kick in around 1700rpm.
    Has your car previously been chipped/tuning box?
    Are any of your injectors excessively noisy/dribbling?
    EGR operating/closing correctly or boost n75 valve (near turbo) working properly.
    Small leak/blockage in boost control tubing.
    Small leak in exhaust, especially the small joining collar in the middle of the system which is prone to corrosion.
    VNT mechanism sticking through part of range.
    Correct MAF.
    Incorrect timing.
    My own 97 A4 tdi becomes much more powerful after towing a heavy trailer all day, then over the following few weeks the power drops back off, and the boost starts kicking in a little later.
  5. Romi-shon
    Romi-shon New Member
    i have a similar problem to this. When excellerating in 2nd gear i get a blue/grey smoke and when going along the motorway it flats out. I wondered wether it was the turbo. I haven't tested anything yet but would like to know your ideas. the smoking seems to be less at the moment. and the car didn't seem to flat out as much once i changed the oil and filters.
  6. inigoj
    inigoj Member
    263
    If you have blue smoke that lessens after an oil change, it sounds like oil seeping throught the turbo oil seals, or maybe timing, you will also probably have oil in the boost pipes and inlet manifold too.
    With VAG TDI's it is recommended not to use a fully synthetic oil, even though they are 'better' they are generally to 'thin'. Instead use a thicker, more viscous semi-synthetic oil, 10w/40 or 15w/40. This will generally stop the smoke.
    Grey smoke to me would generally indicate a poor injector spray pattern/dodgy injector, timing off, dodgy fuel cut-off or fuel adative burning (redex etc).
    Oil leaks will also increase the rate that your EGR valve gumm's up.
    Try cleaning out EGR valve and MAF/MAP sensor and any small tube that may trap oil/crud.
  7. Sm[]key
    Sm[]key New Member
    19
    I'm gonna try another MAF as I have another genuine one and I think the one that fitted isnt. I am gonna replace the fuel and air filters as the are looking a bit rammy!
    Will fit this weekend when I get time!
    The smoke problem I have seems to be getting worse, it is smoking alot more and upto the rev range of 3000rpm now. If I put my foot to the floor I get a big puff of smoke and it clears. If I'm on a quarter throttle smoke is evident in the lights of the car behind me.
  8. Sm[]key
    Sm[]key New Member
    19
  9. Rev-head
    Rev-head Active Member
    2,987
    The car is over fuelling by the sounds of it so would go for boost leak take the engine cover off and check all the pipe work around the inlet manifold and were it leads through the back of the engine ..check intercooler clips and make sure all are tight
  10. K7ERG
    K7ERG Member
    372
    Got a similar problem with my 2.5TDi at the moment. Flat spot between 3000rpm to 4000rpm. And it smokes bad which it never done before. Also MPG is down a bit as well.
    So its a boost leak i have to find. Dont have vagcom to check for faults.
    Craig
  11. rickquattro
    rickquattro Member
    589
    Thats interesting.. I have felt this in a couple of circumstances. Do you know why this is?
  12. inigoj
    inigoj Member
    263
    I think the ECU adjusts the timing to optimal when the engine has been under load for a while. (normally the timing is retarded, as a TDI is tuned for max economy as standard).
    Not sure if anything else is adjusted, fueling etc.
    After towing all day my car is very powerful/torquey for 2-3 weeks (will spin wheels in 3rd) then gradually the power drops off again.
    The increase in power is a lot greater than my tuning box ever produced.
  13. K7ERG
    K7ERG Member
    372
    No faults on the ECU
    Disconnected the EGR valve still loads of smoke. disconnected the MAF and it ran clean. Looks like a new MAF is on the cards
    Thanks Rev-head
    Craig
  14. Sm[]key
    Sm[]key New Member
    19
    My smoke problem is sorted, I fitted a genuine MAF and it runs ok now with no smoke.:moa:
    Must of had a faulty non-genuine MAF?
    Thanks inigoy for the help.:icon_thumright:
  15. Sm[]key
    Sm[]key New Member
    19
    I ran the vag-com tdi timing checker today. It shows my timing slightly advanced at tick over. But within the safe area on the graph.
    Is that a good or bad thing?:sadlike:
  16. inigoj
    inigoj Member
    263
    Slightly advanced is a good thing if you like accelerating.
  17. Sm[]key
    Sm[]key New Member
    19
    Sounds good to me! :yahoo:
    Thanks again:salute:
  18. golisago
    golisago Member
    Although i do buy items from places like G&S&F and other cheaper companys i wouldn't bother with buying maf sensors from here and would recommend the steelership for this item every time......
  19. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    DO I HAVE THE SAME PROBLEM?:think:
    he had a diagnostic plugged into the car(handheld) he said car go's like a bat out of hell! was mentioning overfueling,then over boosting. I think he didnt know what was what,ive been told ecu measures fuel,and that cant be wrong,and ive done the obvious of replacing filters and coolant sensor,and my injector readings are good: -0.75 -0.42 0.66 0.52 mg/str.
    went to another good diesel bloke,here are his words: if reved hard every car will throw out a bit of black smoke (as long as its a diesel) Your cars been ticking over for a full 6-8 minutes now,and when i reved it there was quite a bit of smoke,its cuz its been sitting on idle for nearly 10 minutes(quite normal) but i rev it now for the next 2-3 times theres only a bit of black smoke,again quite normal.......personaly i dont think its overfueling otherwise it would leave loads of black smoke every time,but in your case it leaves as much as any other car when you boot it hard! fuel is measured by ECU so i dont think thats wrong. Try changing your
    ALSO NO FAULTS FOUND OR LOGGED
    "fuel tempreature sensor" now "whats that do" "where is it located"?
  20. truebrummie
    truebrummie Member
    41
    im having same problems maf? what is this. new to all this diesel stuff does this solve the problem
  21. DIPS_A4
    DIPS_A4 SEAT LEON CUPRA R (225)
    570
    mine smokes like anything also but its cus mine has been chipped. quite imbaressing at night time.
  22. Mattmilo
    Mattmilo New Member
    Hey guys wonder if you could be of assistant, I recently just brought my audi a4 2007 and I noticed like some of the posts here I get a cloud of smoke out the back when I start her up or accelerate quickly. I must admit I'm new into the car industry so not that technical at the moment so some help would be nice....i want to make sure it's all fine first because I want to remap the engine but not to sure whether to risk it with the smoke any thoughts?
