Black Edition wheel refurb?
bradyboy Aug 31, 2011
  1. bradyboy
    bradyboy New Member
    Hi all,
    I've recently got an 11 plate A3 black edition & one of my wheels needs refurbing? anyone had any experience of geting these done as I understand there polished round the edges? I'm in essex by the way so if you no any places you would recommend local that would be briliant.
    Also my car suspensions seems to be a realy harsh ride and knocks pretty loud if I hit a hard bump?just wondered if anyone found this with there A3?
    cheers
    Brad
  2. FOX1980
    FOX1980 Foxy
    148
    My S line A3 albeit older 56 plate has a fairly harsh ride when going over bumps e.t.c., I am told its the stiffer suspension that comes with the S line cars.
  3. nally
    nally MPG the new BPH
    2,104
    34
    My sport creeks over bumps, had it checked ive been told its because its a stiffer spring. But I would emadgin the sline are worse. Pick my new sine up in a couple of weeks so ill let you know
  4. eddyd
    eddyd Member
    99
    The wheels are diamond cut around the outside which means the damage needs to be welded, repolished and lacquered. It's quite expensive and not everywhere does it. I was quoted £135 +vat per wheel, but you should be able to get it done cheaper than that.
    Mine knocks too on a badly surfaced road.
  5. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,380
    214
    My wheels are black edition 2011 and not diamond cut :) I tried to photograph them before and the machined surface is dead smooth
  6. eddyd
    eddyd Member
    99
    What are they then? I thought it was the matt lacquer made them not as shiny as others I've had?
  7. paddy
    5,380
    214
    Diamond cut is where they use a sharp tool on a coarse feed to turn the alloy giving a grooved finish much like a old record, this tends to reflect the light well off the angles of the cut giving a different reflected light from different angles.. My wheels are dead smooth and i am not sure if they are painted of just lacquered. the finish i dead smooth almost glass like. If they are lacquered then its a very dark alloy, maybe a tint in the lacquer ?
    This is what i call diamond cut, note the CD type light reflection..
  8. eddyd
    eddyd Member
    99
    You are right they don't have that type of reflection, but I looked at mine again and you can see the old record type pattern (quite faint) in the metal.
    IMO it's a diamond cut or machined type finish, on mine at least anyway.
  9. paddy
    5,380
    214
    Its defo machined but the whole point is if it was diamond cut like the one above then to refurb would be a lot more difficult because the weld area would stick out when machined. As it is then that grey mat lauquer will hid any metal difference and should be easier. mine show no signs of turning as you can see by the close up pics .
  10. PilotAudi
    PilotAudi New Member
    2,352
    479
    I have a damaged one (very minor) and wondered if there was a touch up colour that would disguise the scratch. Currently we have a small white patch showing through.
  11. eddyd
    eddyd Member
    99
    Which bit, the shiny edge the best thing to use is some lacquer or nail varnish to stop the water and corrosion getting under the rest of the paint.
    The inner grey bit is code "L 8AU".
  12. paddy
    5,380
    214
    Is that an Audi touch up number eddyd ?
  13. eddyd
    eddyd Member
    99
    No it's a paint code, Audi in etka quote "8AU" beside the black edition wheel and if you search in paints4u.com it brings up "L 8AU"
  14. bradyboy
    bradyboy New Member
    Cheers for the advice guys, Mines only a very small scuff but i may touch up with abit of lacquer to protect it :)
    As for the suspension I was guessing this was the case, I know sports models have harsh suspension but i think audi took it to the extreme with the s line! & im sure the heavy diesel lump in the front doesnt help!!
  15. Gino1979
    Gino1979 New Member
    Hi - In this boat also. Damage is to edge of wheel only, most of the way round. (None of the titanium finish area is damaged). Company called Prestige Wheels (North West England) can refurb for £108 inc VAT (per wheel).
    However, as they are Diamond Cut, car/wheel needs to be with them for 4 Days.
    Contact at: info@prestigewheels.co.u
    Hope this helps.
    Gino
  16. tanjaz
    tanjaz Member
    These wheels are easily refurbished and can be done at your home address or taken away. try www.perfectiongroup.net very good and good prices too.
    cheers jaz
