Black Colour Codes - HELP!!!!
luvie Aug 3, 2009
  1. luvie
    luvie New Member
    21
    Hello Forum Experts
    A couple of Newbies here looking for a little help on Black Colour Codes.
    The MRS is looking to buy a TDI Sport around 2004 age.
    But the trouble is there seems to be quite a few black's and some of the blacks looking almost Grey.
    Now we Know how fussy wives are!!!!
    She wants Jet black, So far we have found the following
    Phantom Black
    Panther Black
    Ash Black
    Brilliant Black
    Which is the darkest and can any of you experts give a pair of novices some much needed help
    Many Thanks In Advance
    B&V:blackrs4:
  2. Ash B
    Ash B Well-Known Member
    5,831
    Hi
    :sign_welcome: to the forum B&V
    Never heard of Ash Black or Panther Black in the Audi Ranage. Phantom Black a more metallic paint. Brilliant black flat and not metallic, so Phantom Black may be your best bet for your partner. The grey that looks almost black in Lava Grey same colour as my car in my sig below.
    Hope that helps
    Ashley
  3. luvie
    luvie New Member
    21
    Thanks very much
    So there is only 2 sorts of Black then?
    Basically a Flat black or a Metalic?
    TIA
  4. Ash B
    5,831
    Hi
    Yes there only two types of black. Brilliant Black and Phantom Black
  5. middy
    middy New Member
    13
    hi there ,new to the forum but im sure theres ebony pearl metallic too ,mines a 2005 sport tdi , cant be sure of colour code at minute but sure its different to the other two
    cheers mark
  6. Ash B
    5,831
    Hi Mark
    :sign_welcome: to the forum...You are correct, i just had a look in a booklet i have on the pre-facelift A3 and it does State ebony pearl. But that colour no longer used in the Audi range. Think it was only really used between 03-05 on pre-facelift A3. How you finding your 2.0tdi?
    Ashley
  7. middy
    middy New Member
    13
    hi benskin ,cars fine ,its only the 1.9 bkc engine ,there was method in my madness as we use the same engine in the forktrucks I work on so makes fault finding (if ever i need it) a little easier ,bit under powered but only for the better half to thrash to work and back
    They must have used it for a short while on the facelift models as mine is single grille
    cheers mark
  8. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    Mines Brill Black and it looks so deep when polsihed right...
    It's gloss black :D
    A few pics to help you out!
