Black box with 6 rubber pipes???
lifeboatcrew Apr 7, 2011
  1. lifeboatcrew
    lifeboatcrew New Member
    22
    Hi folks, was just away to change glow plugs as my car sometimes goes into limp mode at high speeds. While taking things apart I found a thin black pipe at the back of the engine not connected to anything. Followed the pipe to a black box with 6 other numbered pipes. Can anyone tell me what it is and where does pipe 3 go to???? Thanks!
  2. mike foster
    3,967
    Don't think glow plugs work when the engine is up to temperature mate. Certainly I've never heard of them causing a car to go into limp mode !
    What engine is it and can you post pics of the pipes in question ?
  3. lifeboatcrew
    22
    Yeah I did think that but it struggles to start in the morning and it did flag up a glow plug error couple weeks back.
    It's A3 2.0 tdi 8p will try n get some pics up if I find out how to!
  4. lifeboatcrew
    22
  5. mike foster
    3,967
    Think you have to post them to photobucket or something and then post on here!
  6. lifeboatcrew
    22
    Here's a video! Think it should work
    foster;1221433]Don't think glow plugs work when the engine is up to temperature mate. Certainly I've never heard of them causing a car to go into limp mode !
    What engine is it and can you post pics of the pipes in question ?[/QUOTE]
  7. lifeboatcrew
    22
  8. mike foster
    3,967
    Looks like what is called 'vacuum hoses with connection' that plugs into the solenoid valve block.
  9. Lewis583
    956
    91
    from the video i think that is the pipe that runs down to the actuator on the turbo for the vnt
    1 - Mechanical exhaust gas recirculation valve
    2 - Vacuum reservoir
    3 - To vacuum unit for charge pressure control
    4 - To vacuum unit for exhaust gas recirculation cooler change-over
    5 - Solenoid valve block
    6 - Vacuum supply line
    >From tandem pump to solenoid valve block
    7 - Tandem pump
    8 - Air cleaner housing
    >With connection for vent hose
  10. lifeboatcrew
    22
    Thanks very much guys for your help! Would that pipe being off cause the car to go onto limp mode at high speed?
  11. ste
    ste reverse gear
    121
    hi, that pipe should connect to the actuator on the turbo. it would cause problems at high revs if not connected. you should re-connect it ASAP and try the car
  12. Lewis583
    956
    91
    As said yes it can cause limp mode due to the engine management not being able to regulate turbo speed and therefore boost pressure.
