bkd injector duty should reullts be so different between cylinders
nokia_aid Nov 4, 2011
  1. nokia_aid
    nokia_aid Member
    47
    just tested my injector duty and there are not alll quite the same,results were
    cyl1 cyl2 cyl3 cyl4 measured in mg/str
    2.99 -3.01 -0.19 0.14 as it the car got warmer they went to
    2.82 1.6 -0.73 -0.45
    EDIT
    WHEN IT GOT UPTO FULL TEMP
    CYL 1 CYL 2 CYL 3 CYL 4
    1.71 -0.74 0.72 0.42
    should there be such a big difference between the cylinders
    cheers in advance for your help
  2. nokia_aid
    nokia_aid Member
    47
    ok looking on google iv got that cylinder 1 is maxed out and cyl 2 could be low cos its trying to compensate,just need to figure out what would cause that,google searching i have figured
    worn cam
    low compression
    faulty injector loom
    pourus head
    any one else know of anything that might cause this
  3. Broken Byzan
    13,237
    465
    Looks like the age old injector failure. IIRC there is some kind of action where Audi replace the faulty units with new improved ones
  4. nokia_aid
    nokia_aid Member
    47
    the strange thing is though i have already replace the injector in cyl 1 and the mechanic said when he took them out that the injectors had already been done before that cos they were exchange units.
