Bkd cam timing
Ade6 Jun 5, 2013
  1. Ade6
    Ade6 Member
    101
    Im still having issues with my a3 2.0tdi. In the morning/ when its been stood for a while and let cool down i start it, it missfires into life and puffs a cloud of bluey/white smoke that stinks of diesel then its okay! Had new turbo,glow plugs, glow plug loom. And a diffrent tandem pump. Still the same. Orderd my injector seals to try them. Im wondering if its my timing? From cold the injector readings are fine. The idle consumption goes upto 2.0l/h for a second or two thwn back down to 0.6-0.4 l/h. Is that normal? Also my torsion value is 0.0. Thanks
  2. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    that use to happen to mine ended up being the head ;(
    would run fine just that it it chuff out smoke after a run and its left to cool for a while
  3. Ade6
    Ade6 Member
    101
    What happend to yours then?
  4. tdi-man
    1,783
    64
    would start and run fine once up to temp and parked up for a while would smoke for say 20 secs and clear and run fine .
    slight loss of water but not a lot.
  5. Ade6
    Ade6 Member
    101
    I wouldnt say mine smokes for 20 seconds! Just one puff of smoke maybe 2-3 seconds and its fine! I havent noticed any coolant loss (touch wood) im thinking oil is seeping into the bore thry the injector seal and thats causing the smoke/missfire? Also its used from max to half way on te dipstik within 2-3 weeks! How did you diagnose your head?
  6. Ade6
    Ade6 Member
    101
    Also my coolant temp sensor on vcds showed my car at 81 degrees when my gauge on the car was on 90! Could this be a fueling problem?
