BKD CAM TIMING
Rodney5950 May 3, 2013
  1. Rodney5950
    Rodney5950 Member
    46
    CANT SEEM TO FIND A THREAD ON CAM TIMING ADJUSTMENT AND I THINK I AM IN NEED OF THIS, HAVING RUNG A FEW GARAGES AND EXPLAINED THAT MY TORSION VALUE IS 6.6 WHICH IS THE PROBABLE CAUSE OF MY JUDDERING AT IDLE, NONE OF THEM SEEM TO HAVE A STRAIGHT ANSWER AS TO WHETHER THEY CAN ADJUST THIS FOR ME, MY MUMS 2.0TDI SB WENT IN FOR A CAMBELT CHANGE AT AUDI AND THE TECH I SPOKE TO HAD NO CLUE WHAT I WAS TALKING ABOUT WHEN I TOLD HIM ABOUT THE TORSION VALUE BEING TOO HIGH ALTHOUGH HE HAD DONE THE TB.
    I READ A THREAD ABOUT A MK5 THAT HAD THIS ISSUE AND AFTER A TB CHANGE HIS CAR WAS JUDDERING AND VERY POOR OF FUEL WHICH IS WHAT MINE HAS DONE, HE ALSO STATED THAT UPON INSPECTION THE BOLTS WITHIN THE OBLONG HOLES THEY WHERE SAT IN DIFFERENT POSITIONS AND SOMEONE SAID THEY SHOULD BE IN THE CENTRE ON BOTH CAMS FOR THE TIMING TO BE CORRECT?? I FOUND A PAGE WITH DIAGRAMS IF WHAT IM TRYING TO EXPLAIN, ALTHOUGH A DIFFERENT CAR, THE CAMS ARE TO ILLUSTRATE MY EXPLANATION, I PLAN TO ADJUST THE CAMS MYSELF AND I WAS HOPING SOMEONE COULD OFFER ME A STEP BY STEP GUIDE ON HOW TO AND CORRECT ME IF I HAVE WAFFLED ON...REASON I USED THAT 206DIAGRAM IS BECAUSE IN SECTION 6.2 ITS STATED THAT "When the 3 fastening bolts are slackened, the gears are free to rotate (within the limits of the oblong holes) .This type of assembly makes possible :
    • improved accuracy of timing
    • better distribution of belt tension between the different runs"
    http://www.peugeot206cc.co.uk/repair-206/206/info/gb/b1bbm7k3.htm
    1. ON THE LINK, THE DIAGRAM IN QUESTION IS 6.2
    2. ON A BKD..DO I LOOSEN THE 3 SMALLER BOLTS TO MOVE EACH CAMBKD 16v diesel tuning snippets
    3. IF NUMBER (2) IS CORRECT, DO I MAKE SLIGHT ADJUSTMENTS WHILE I CHECK ON VCDS?
    ANY HELP WOULD BE APPRECIATED THANKS
  2. tdi-man
    tdi-man Well-Known Member
    1,783
    64
  3. tdi-man
    1,783
    64
    THESE guys can set up up for u
  4. tdi-man
    1,783
    64
    if you don't know what your doing don't do it
  5. SL11CKK
    SL11CKK Active Member
    712
    My mates torsion value is around 2.4 and also juddering on his BKD. Although he is pretty sure after the timing belt change its started doing this.
    I believe its the cam more next to the front of the car that needs adjusting.
    Theres a good guide on tdi forums that gives advice on how to do so.
  6. tdi-man
    1,783
    64
    torsion value is the front cam and should be 0.5 once this is set u will need to adjust the rear cam to match the front cam by setting the marks up on your flywheel to tdc and pining front cam when u have it at 0.5 then adjust rear cam pin it and tighten up
  7. NHN
    29,596
    1,782
    You need to lock the cams in place & then you have it as it should be, some garages don't do this & you suffer with loads of issues, of which I did for 2 years until a mate mastertech did a belt change etc & fixed my issues immediately.
    martinivw likes this.
  8. 20pricey11
    20pricey11 Member
    73
    Which way do you turn the front cam as mine is -2.5
  9. A19quattro
    A19quattro Active Member
    664
    102
    43
    Is this a specialist job or should any good garage be able to do it? I have wondered about my car in relation to fuel economy, need to check the torsion value on VCDS I guess, anyone advise or have a How=to n how t do this?
