Bkd boost gauge figment??
r7no Nov 26, 2013
  1. r7no
    r7no New Member
    I'm looking to fit a boost gauge to my 8p bkd tdi. I'm stuck on what hose i need to tap into for the feed to the gauge as I've seen it done a couple off different ways and can't find it anywhere on here . Any advice or pictures would be much appreciated
  2. Jack_tdi
    Jack_tdi Member
    287
    12
    why do you want a boost gauge?
  3. r7no
    r7no New Member
    I've got a hybrid turbo along with a revo map , panel filter and full stainless system would just like to keep a eye on what's going on mate
  4. Jack_tdi
    Jack_tdi Member
    287
    12
    Fair enough, was expecting you to say "coz they are cool init" lol
    Can't really help you with where to tap into the boost hoses but the majority of the standard ones are plastic and flexi hose. May not be ideal to make a secure connection too. You can track the pressure through the obd port though I used to do it with my samsung galaxy nexus and a Bluetooth obd adapter. Use an iPhone now so it's a little more expensive to do. This could be an option for you though....
  5. Rhyso
    Rhyso Well-Known Member
    1,536
    320
    You want to tap into the hose coming off the EGR valve at the front of the engine
    two ways of doing this; tap into the existing hose or buy an EGR delete pipe with a boost hose take off point. The latter would be better as you are unlikely to introduce a boost leak into the system
    Darkside Developments sell the pipes
  6. ElliottB
    ElliottB Audi A3
    198
    I have a EGR delete from darkside developments along with there hard pipe boost kit and my boost gauge pipe comes off there as Rhyso said.
  7. tehtoymachine
    tehtoymachine New Member
    Hi, slightly unrelated to the boost gauge question but do you have any pictures of the darkside hard pipe kit fitted?
    Looking into aftermarket hoses for my 2.0tdi 140, hoping to get rid of the loose fitting standard fiment, the hose going to the imf/egr is starting to become loose and I'd rather buy uprated hoses than keep replacing the standard ones over and over!
