BIZZARE PROBLEM - HELP PLEASE :(
bigfoot0387 Jul 18, 2009
  1. bigfoot0387
    bigfoot0387 A3 Abuser
    13
    Hi guys i am new here and to start i am having serious trouble with my R reg 1998 1.9tdi a3
    Ok heres the story when you go to pull off the left front wheel sticks on and makes a griding/winding sound.
    After you are going it stops sticking/making the noise.
    Once you stop/slow right down to a halt and pull off again it will do the exact same.
    So far the following has been replaced.
    Gearbox
    Driveshaft
    Brake pads
    Brake disks
    Any ideas as this is beginning to really get to me.
    thanks
    Ben
  2. dubplate Dan
    dubplate Dan swirl buster
    could be a wheel bearing
  3. rowdyboy
    rowdyboy Member
    804
    19
    I know its a long shot but i had a similar problem on a previous non Audi car. I eventually found that one of the ABS sensor mounting bracket bolts had sheared, allowing the bracket + sensor to wedge against the hub. It was not obvious at all to look at and took ages to work out. The noise it made was horrendous.
    Im not sure if the Audi system is the same but its worth a look if nothing else.
