Bizarre S3 Low Oil Pressure warnings....
KarlHeinz Apr 7, 2012
  1. KarlHeinz
    KarlHeinz New Member
    24
    Hello all!
    I have a 2000 Audi S3 1.8T APY
    Car is mint but for one annoying issue that rears it ugly head randomly
    The Low Oil Pressure light has a habit of blinking on with the three bleeps... It usually turns itself off after 10 to 20 seconds. The car sounds and feels normal, no dodgy engine sounds at all...
    first time it happened, I brought the car to my local Audi specialist who reckoned it would be a blocked pick up in the sump.
    So off came the Sump. The pick up and sump pan was fine, no sludge build up.
    he ran a pressure test and it was fine, just a little below the standard psi and well within normal levels
    then that it... The issue was cured for the last 6 or 7 months! Only to randomly happen again, this time, after getting it serviced and again while reversing into the driveway at 1,200rpm!
    then fine
    The engine sound perfect at all rpms
    I would appreciate any input you all have
    thanks guys!
  2. aragorn
    18,382
    831
    Try a new pressure switch?
  3. KarlHeinz
    24
    Didnt try that Aragorn... Is that a DIY job or a mechanic job?
  4. sportquattro
    sportquattro Active Member
    835
    51
    As above its got to be one of two possible things either you really do have low pressure which would be a oil pump/blockage issue or its a spurious warning in which case its a faulty sensor, from what you describe it sounds like sensor is most probable, and certainly easiest fix.
  5. aragorn
    18,382
    831
    yeh, it just unscrews from the oil filter housing.
  6. Kami
    Kami Member
    37
    My gf's 9n polo did this, replaced the switch and it still did it. In the end I had to replace an earth strap on the engine and the problem fixed itself.
  7. murran
    murran Well-Known Member
    1,545
    39
    what oil was put in it at the last service?
  8. KarlHeinz
    24
    Thanks for your comments guys, I will look into the pressure switch and earthing... The oil used is Fuchs Titan GT1 5w40. I'm don't think the bearings are worn as surely the warning would always display when driven? not to mention make the engine sound dog rough? The light has only appeared 3 or 4 times in the 7 months I've owned the car...
  9. KarlHeinz
    24
    It turned out to be a faulty pressure switch. Cheers Aragorn!
