Bit :( at my Stage 1 figures
scotty_24 Oct 6, 2012
  1. scotty_24
    scotty_24 Well-Known Member
    1,037
    245
    I've had my stage 1 AMK S3 rolling road'ed today and I'm a bit unhappy with the results to be honest.The car has 93k on it so I appreciate its a 51 plate and getting on, but I was honestly expecting more.
    It made 239.5 bhp and 275 flb torque. The power cure is very smooth as is the torque. Boost peaks 1.5 bar and holds 1.2. Air fuel peaks 14.4 drops to 13.
    Mods include badger 5 turbo intake pipe with Jetex filter and REVO stage 1.
    Am I over reacting thinking the REVO / B5 TIP combo would have got me more power?
    s3123 likes this.
  2. badger5
    9,472
    1,988
    13 afr lowest it goes?
    what dyno?
  3. scotty_24
    1,037
    245
    Yeah the lowest it goes is 13 being honest I don't understand AFR at all ha ha.
    dyno dynamics at Evotune in Durham
  4. R-Tech-Nick
    R-Tech-Nick Active Member
    150
    51
    I found out this week a lot about some torque control issuse with the S3 and TT and also found on some dynos which have slow accerlation rates or PID based eddy current brake control will cause the car to give a torque reduction in power when cannot be seen with VCDS logging, A higher sample rate will be needed to log the engine to see where the ecu is sheding power. In the road the car might we running a little more power then it is on the dyno.
  5. scotty_24
    1,037
    245
    Bhp at wheels boost and afr
    Afr & engine power
    Power engine & torque
  6. scotty_24
    1,037
    245
    Theres the 3 graphs I got from today to help, and a pic of my set up. I think I need a 3" down pipe and a front mount to compliment the B5 TIP
  7. jojo
    28,886
    3,539
    I have a stage1 map and B5 induction aswell, 270 horses!
  8. scotty_24
    1,037
    245
    Cheers mate. Now I want to torch mine.
  9. superkarl
    superkarl MAN OF STEEL
    9,468
    2,427
    good torque figure. and bhp is calculated from torque. so it is a bit odd
  10. scotty_24
    1,037
    245
    Yeah the torque is exactly as I expected and I'm pleased I'm not in the rod bending area of 300lbf. Just wish the power was at least 250 ha ha.
    It keeps up neck and neck with my friends remapped megane 225, so on the road to me it's fast and drives well!
  11. Big_jim
    Big_jim Member
    119
    Does it feel much faster than before the remap?
  12. scotty_24
    1,037
    245
    Yep the difference is unreal, the in gear motorway acceleration is very much improved and when I boot it I have a huge grin in my face every time!
    To be honest I'm happy, I'm just a) gutted it didn't make more power and b) paranoid something's wrong ha ha
  13. Big_jim
    Big_jim Member
    119
    Im thinking of getting mine done. But as im trying to sell it (ish) is it £300 wasted???
  14. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    196
    Lol rub it in jojo! :)
    Not that great IMO , I thought you would make at least 255bhp ....
    Was that on shell optimax fuel?? Made a difference when I had my focus st 225 265 bhp edition dyno'd. Experimented with / without.
    Either your car not running right or his dyno is out. Get your s3 scanned with vagcom.
    Cheers, Sean
  15. Jimgrim77
    Jimgrim77 Member
    957
    20
    Always run high octane. Mine seems fondest of the shell v-power but each to own.
  16. scotty_24
    1,037
    245
    Yeah it always gets V power, never anything else. I work in a vW dealer and it was scanned 2 weeks ago no faults
  17. s33nyboy12
    1,484
    196
    I think maybe, if your funds allow , take it somewhere else to be dyno'd.....? Possibly tired ko4 turbo. I think westy got good results with stage one when he fitted a brand new ko4 but I might be wrong... Do some logs on the road whilst driving and post them then if there is anything wrong tuffty or bill would be able to see from logs and tell you.
    Sorry not much help mate, good luck
  18. Big_jim
    Big_jim Member
    119
    Ok, im new to the Audi world and keep hearing about Vagcom.
    Is it worth me finding somewhere to plug mine in to sell if it all running as it should?
  19. scotty_24
    1,037
    245
    To carry out logs do I just download vcds lite from Ross tech and buy a £6.50 lead off eBay? Is it simple?
    Keen to try to log some data to try and suss this one out
  20. Pops848
    Pops848 Active Member
    597
    54
    Simply, yes it is that easy. However you will have limited functions and eBay cables can cause a whole host of problems. If your going to keep a VAG car buy the VCDS system properly. After that you can do anything ;-)
  21. scotty_24
    1,037
    245
    lead ordered, will download vcds lite to my lap top and go out to do some logs next week.
    Anyone know which measuring block numbers would be best to log?
  22. colicabcadam
    colicabcadam Guest
    there's 2 ways you can look at this,
    cry, moan and ***** about it and go into a mental state of this is not right, through more money at your car etc
    <or accept that your car was run from a different dyno to others - go and do a 4th gear pull from 62-124 (or the limiter, unsure of gearing on the s3) mph and time it, this is a far better approach to comparing cars IMO
    not quite sure, why as car nuts we chase peak power bhp, i think a fairer figure to chase would be how much bhp is available from a certain rpm, let's say your car makes 200bhp+ from 5,000 rpm and peaks at 240, that's better than someones who makes 200+ from 6,000 rpm that peaks at 260
  23. scotty_24
    1,037
    245
    Im not crying about it, Im just interested to find out if somethigs up with the car.
    Revo are renouned for being quite high power, and I was supprised at the power output my car had.
    I have the vag come lead coming tomorrw ao I will do some logs and if everythig is fine, Im more than happy to accept that thats just what the cars running.
    What measuring blocks are best to log ?
  24. jojo
    28,886
    3,539
    Wouldn't really get too hooked up on RR run figures, they are only good for pub talk from my experience. I have had my car RR'd on a minimum of five different rollers over a 10 year period, and I have powerplots for between 240-270bhp, so does that mean my car was on an off day when it made 240? No not really, considering it was exactly the same spec/setting when it made most of these figures, the 270 is with the B5 3" intake installed with the exact same map I've had all these years!
    The only real comparison is to have it RR'd with a group of similar cars on the same day in similar conditions, then you can gauge if the RR is an optimistic one or a low reading one.
  25. Sam_
    Sam_ Down under
    3,038
    480
    Sounds like it's healthy and going well. All that really matter is it's putting a smile on your face. Forget the numbers!
  26. badger5
    9,472
    1,988
    reminds me of the old Ajec Dyno day... where most S3's made those power levels...
    DD rollers for you.. meh!
  27. <tuffty/>
    21,161
    3,838
  28. scotty_24
    1,037
    245
  29. Gops
    3,198
    666
    Mate don't be down! I had the same feeling when my car was dyno'd at 251bhp and 270lb ft torque. I was expecting abit more power but those figures didn't seem right.. I was so upset but then you realise that the car is still quick! Mines do e 172k on its original turbo and my actuator is quite weak so putting them into the equation it's not that bad! And I had a play with a remapped ST and it couldn't do anythin so I was happy! For me, I plan to get a new actuator, DP and relentless cat to ease flow more. With more flow in, it's gotta come out so try a downpipe? If the car makes you grin then don't worry at all!
    gops
  30. scotty_24
    1,037
    245
    Yeah the car does driver well and the difference since the map is night and day. It is literally neck and neck with my friends remapped 57 plate megane 225.
    Yeah Im saving for an exhaust at the moment as I hear the downpipe makes a difference, I also want a bit more of a meatyer sound from the car as well.
    Exhaust intercooler rods and stage 2 required :) ha ha
  31. colicabcadam
    colicabcadam Guest
    dude - you are comparing dyno numbers to cars run on different days, with different air pressure and air temps as well as different dynos !!!
    did you get a before and after run ?
  32. scotty_24
    1,037
    245
    Well the cars been rolling roaded again at the same place as last time.
    I'm happy to report that the car is sorted!
    Many split pipes replaced, a full service and a relentless 3" downpipe later and she ran 262 bhp today :)
    just goes to prove how vital it is to check and replace split pipes. All of the pipes under my Inlet manifold were split, they have now all been replaced with the forge and oem items.
    roll on front mount and stage 2 :)
    superkarl likes this.
  33. badger5
    9,472
    1,988
    smoke test FTW...
    I may have been saying this a lot lately on forums and FB
    so so very common for these 'old' motors to leak like a proverbial seive
  34. basil brush
    basil brush Active Member
    497
    163
    43
    What a smoke test is seems fairly obvious but how do you carry one out bill ?
    Baz
  35. badger5
    9,472
    1,988
    Do I carry out smoke test?
    yep, daily.. every remap car starts with a smoke test... and often Stops there..
    many cars leak, and without them being fixed, no mappy, and engage fixing mode instead
    invaluable tool my smoke tester
    many many many many MANY customer come in saying their cars are driving fine, they "checked" their pipes for leaks as they read its an issue often, and when I attach my smoke tester to the MAF and it blows copious amounts of smoke out of split pipes, they are stunned.. Visual checking pipes is not going to find the leaks peeps.. Smoke test reveals them. I remain surprised how few garages invest in this kit. Saves shed load of wasted time. Finds leaks efficiently and quickly.
  36. basil brush
    497
    163
    43
    Yes but how is it done ?
    Baz
  37. Scullies
    Scullies Well-Known Member
    1,543
    657
