Bilstein PSS10 Coilovers For Audi 8P S3 (May Fit Golf R & TTS)
Phil_T Aug 23, 2012
  1. Phil_T
    Phil_T Revo Stage 2+ Audi S3
    240
    I will first say I dont come on here much so it will be best to PM me or to email me philipturner14@hotmail.com
    As above may sell the coilovers if I get what I want for them to make way for
    some others I am after. Spec & pics below. PM me is best for me to reply
    to.
    They have been on the car 10,000 miles and still feel like new, They are
    stainless steel & height & rebound adjustable. They also have lifetime
    warrenty unlike other coilovers.
    Utilizing Bilstein’s monotube shock absorber design for heat dissipation and
    ride control, the PSS10 Coil-Over System, evolved from the PSS9 system, adds a
    matched performance spring and threaded ride height adjuster to provide a
    complete suspension system for your vehicle.
    "Click" From Comfort to Competition With No Tools or Jacking
    Required
    The Bilstein PSS10 Coil-Over System offers ten vehicle adjustment settings
    and includes numbered adjusters at the base of the shock body so you know
    exactly what setting you are on without counting clicks. Set your vehicle low
    and tight for optimized performance or revert to a more stock-like ride height
    and handling characteristics.
    This system features both coil-over and standard monotube gas pressure shocks
    with performance level valving along with application specific, progressive rate
    coil springs. Ride height adjustments can be made on the vehicle without
    removing the suspension. The solid aluminum spring seat and lock nut allow a
    selective adjustment of the vehicle's ride height. Spring travel and vehicle
    body height change, but the spring seat remains pre-loaded throughout the
    allowable range of adjustment.
    • Ride height adjustable from -1.0" to -1.75" (front) & -1.0" to -1.75"
      (rear. minimum 1" lowering)
    • Wrenches to adjust front and rear ride height included!
    • Lighter weight reduces wear and tear on suspension
      components
    About the Bilstein Shocks Included in this System
    All Bilstein gas pressure struts/inserts and gas pressure shock absorbers
    operate on the same principle. They are manufactured with the rod pointing down
    into the strut tube, thereby utilizing the thicker, stouter body portion of the
    shock absorber to dissipate side loads. Consequently, due to the increased
    diameter and surface of the pressure tube, the Bilstein gas pressure
    strut/insert or shock is better suited to take increased side loads when
    compared with the conventional version.
    Additional advantages, based on development strongly influenced by the
    motorsport industry, include greater stability, better road handling, and
    accurate steering. And extremely high quality manufacturing and materials as
    well as a weather resistant coating to resist oxidation, mean Bilsteins will
    last approximately four times as long as Original Equipment.
    Battling Heat Build Up
    Conventional shocks trap the heat within the shock body and prevent adequate
    dissipation, making them prone to heat build up, fade and eventual failure.
    Bilstein's patented design allows the excessive heat from the oil to transfer
    to the outer surface of the shock body and dissipate more efficiently. The
    dividing piston also permits the oil to expand as heat builds, preventing
    aeration (foaming) and viscosity loss. This allows the shock to maintain full
    damping characteristics as temperatures rise.
    The tube of a Bilstein gas pressure shock or strut is fabricated using a
    special extrusion method. This process achieves an extremely tight
    peak-to-valley tolerance and maintains consistent wall thickness. Bilstein's
    seamless monotube design provides superior tube strength while maximizing heat
    dissipation and shock life.
    Ride Comfort and Performance Without Compromise
    The piston head design allows independent tuning of the compression and
    rebound damping forces to provide optimum ride comfort and performance without
    compromise. It features fewer parts than most conventional designs. The
    product's simple, yet exceptionally functional digressive design contributes to
    the extreme durability and long life of Bilstein Shock Absorbers.
    Better Built
    Bilstein's shock bodies are precision formed through a unique seamless
    extrusion process. This provides superior strength along with high finish
    tolerances. The shock body is then treated with a special paint finish durable
    enough to withstand grueling 240-hour salt spray tests. The finished body is
    mated with a solid, induction-hardened steel chrome plated and polished shaft,
    machined valving components and highest quality seals.
    Bilstein products are backed by an aftermarket lifetime warranty.
    I am looking £800 collected unless you want to arrange your own shipping
    & pay for it. No shipping outside UK
  2. shady-ninja
    shady-ninja Active Member
    999
    53
    that look hardcore
  3. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,767
    364
    Dibs
  4. Phil_T
    240
    Sold
