Bigger discs?
JamesA3 Apr 13, 2004
  1. JamesA3
    JamesA3 Member
    238
    not sure I've got the cash for my planned brake upgrade so would fitting massive discs with standard calipers make much of an improvement?
  2. DavidR
    DavidR Active Member
    1,296
    No.
    1. It is hard to fit much bigger discs over a standard caliper - I don't even know if there is such a disc made.
    2. The pad contact area would be no bigger on the new disc
    3. Cooling would still be poor
    4. Caliper flex would still be evident - therefore the pedal feel would not improve
    5. If, by some miracle, you did manage to increase the reardation on the front, the brake bias would suffer adversely...
    Suggest that you put green stuff (or similar) pads on OEM rotors with upgraded stainless steel brake lines and better fluid. A good budget solution.
  3. JamesA3
    JamesA3 Member
    238
    thanks!
