Bigger Brakes
james0808 Apr 8, 2006
  1. james0808
    james0808 Active Member
    3,548
    hi all,im new to the audi scene(from vw)and i need some bigger brakes for my A4 tdi 130.Any suggestions on what is a decent upgrade,will brakes from a R32 fit the A4?
  2. I know this mught not help much but I was after this answer some time ago.
    I know that the 225 TT has bigger brakes but uses the same callipers, you should be able to fit the bigger discs if you use calliper spacers.
    If you do get a definitive answer to this using OEM parts i'd be interested to know.
  3. simon_golf_tt
    simon_golf_tt Member
    249
    The R32 discs and TT discs have the wrong PCD it's 5*100. The A4 is 5*112. The calipers may fit, though I've not heard it being done before.
    The B5 S4 front calipers and discs are supposed to fit - plenty of guys on audiworld.com have fitted them. They are heavy though and therefore don't help handling (unsprung weight). The B6 S4 front discs and calipers also fit and are lighter than the B5 ones. Finding a second hand set might be tricky though.
  4. MarcStanford
    MarcStanford Tankman
    13
    Have recently replaced front rotors with same size Brembo discs and fitted Pagid Blues in the standard calipers. Braking is much improved with more precise modulation from speed. I also replaced the pads in the rear with uprated versions halfway toward the race spec ones up front.
    Might be a simpler and cheaper option than what you are looking at?
  5. james0808
    3,548
    ive tried the R32 calipers and they dont fit.is there any bigger brakes than 288 on the A4 range,i might try some breakers.
  6. dan1
    dan1 Member
    37
    hi
    ive heard you can fit a6 brakes which are 312 or somthing around there, you need the new disks and the caliper carriers of the tt...
    Not sure on specifics, but audi world had someinfo on this... this would be fairly cheap, awesome-gti do the calliper carriers for the tt new....
    will try and find out more....
  7. dan1
    dan1 Member
    37
  8. james0808
    3,548
    nice one,thats what i was after. /ubbthreads/images/graemlins/beerchug.gif
  9. s3bow
    s3bow Member
    378
    Still got the R32 calipers ?
    Chris.
  10. james0808
    3,548
    ive got the full front set up inc.splash guards.i will send you pm.
  11. james0808
    3,548
    [ QUOTE ]
    [/ QUOTE ]
    Any ideas on how much i should expect to pay for a decent set /ubbthreads/images/graemlins/confused.gif
  12. james0808
    3,548
    I mean the B5 S4 front brakes,i guess ive got more chance of finding a set of those.
  13. whisky180
    whisky180 Member
    91
    i have an s4 and i will be upgrading brakes shortly, if your interested in my old ones let mr know regards tony /ubbthreads/images/graemlins/laugh.gif
  14. james0808
    3,548
    [ QUOTE ]
    [/ QUOTE ]
    pm sent.
  15. scoTTy
    scoTTy Active Member
    1,962
    Whisky180 - do you have a B5 or B6?
