Bigger brake options
avant1980 Apr 7, 2011
  1. avant1980
    avant1980 Member
    67
    okay running a 2.0tdi atm so it has 288mm front brakes, basically they are up to the job [ got a race3 remap] been tryin for ages to get 312mm brake carriers so i can stick on bigger discs. was wondering will there be a problem with the back plates or will a set of 312's go on no problem. if i cant get the carriers wld a set of brembo max discs , decent pads braided hoses & new brake fluid do the job.
  2. ultramodz
    ultramodz 06 A4 2.0T FSi S-Line SE
    515
    You can use the S4 discs with different carriers - the calipers are the same.
  3. jwhat
    jwhat Member VCDS Map User
    541
    No the tdi callipers are smaller than the 2.0t one's.
    I don't know if you will need new shields or not, someone would ahve to check ETKA for you for the part numbers.
    If you want a bit more stopping power, you could get a set of 2.0t callipers, pads, disks, and carriers. They are 320mm I think and then the S4's are 343 or something (just carriers and disks different than the 2.0t).
  4. avant1980
    avant1980 Member
    67
    ok will try & check for prices of the 2.0t setup, will give gsf a shout nx wk though sometimes they just cant be arsed on the phone
  5. ultramodz
    515
    Ah yes, you're right :)
  6. drmole
    drmole Well-Known Member
    1,549
    standard 2.0t 321mm founds these really good for standard great stopping power
    but i will be upgrading to the ones on far right mainley for looks same spec as rs4 8pot only mad by alcon
  7. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Darren i want first dibs on your 2.0t Brakes.
  8. drmole
    1,549
    no probs mate you have it ill even strip the red off coz i know u not fussy on them red lol
  9. CMD
    3,015
    17
    Any idea when you are pulling the trigger on the big brakes.
  10. drmole
    1,549
    soon as i get a spare 2k lol would love them asap tho theyd look amazing in the wheels
