Bigger/better brakes.
Cozza McA May 16, 2013
  1. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    73
  2. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    604
    Hi mate what car you got ?
  3. Cozza McA
    410
    73
    It is an A3 1.6FSI.
    Now I know some people will say its not worth it, but my driving style is pretty hard on the brakes.
    Also stopping power is a big factor in a car.
  4. Johnny Bravo
    Johnny Bravo 6+1 Gears Bronze Supporter Audi A3
    898
    69
    Those may not work with your car. Tha ad says they are for MK4 Golf. I'm not sure they fit A3 8p which shares the platform with MK5&6 Golf.
    Also, if your current brakes are the 280mm ones, you'll also have to change the hubs as the current ones have the carriers built-in.
  5. Kelza
    3,078
    604
    Speak to n8 as i,m sure he can sort u out
    N8 likes this.
  6. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    mk4 golf brakes wont fit an 8p model as pcd is 100 on mk4 and 8p is 112
  7. Cozza McA
    410
    73
    Ok thanks. TBH i dont think my current disks as even as big as 280mm. The add is a bit miss leading, says MK4 TT S3. As for the hubs how much hassle/cost would this be?
    Will do he has sorted me out before :)
  8. TDI140
    TDI140 Well-Known Member
    1,624
    174
    You need a set up from a car that has 5x112 stuf pattern otherwise finding discs that fit those calipers will be a major issue, if i find some AMG calipers and discs at the right price ill be selling my golf gti edition 30 set up, or go to breakers yard and see if you can find some off a golf gti or edition 30 they are 312mm
  9. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    Are standard 140's 256mm?
  10. Cozza McA
    410
    73
    Right now I know what I'm looking for so thanks. Spotted these on the bay. http://item.mobileweb.ebay.co.uk/viewitem?itemId=221217678467&index=4&nav=WATCHING&nid=18120452659
    Am I on the right tracks, even although they are a bit rusted..
  11. TDI140
    1,624
    174
    Yh they will fit, i have them on mine but off an edition 30 golf and mine are factory colour red
  12. Cozza McA
    410
    73
    Ok good making progress haha. Are they a simple swap job or new hubs as previously stated.
    Yeah a lick of hammerite wouldn't go a miss.
  13. TDI140
    1,624
    174
    If yours is a 2.0tdi 140 then straight swap
  14. Cozza McA
    410
    73
    Unfortunately it's not. I have the 1.6FSI Model.
  15. TDI140
    1,624
    174
    If your struts are same size as 2.0tdi model it will be fine then i think 2.0tdi size is 55mm not sure though
  16. Cozza McA
    410
    73
    Ah right my struts are 50mm So how does that confuse thinks..
  17. Johnny Bravo
    898
    69
    I know that some 2.0 FSI came with 50mm struts. You can search at brakers for the hubs. This way you won´t have to change the struts.
  18. Cozza McA
    410
    73
    Asked the main man N8 about the MK5 golf GTI brakes and he said the would fit with out any alterations.
    So properly confused now.
  19. Black
    Black Member
    49
    Same question, I drive 1.9 TDI 50 mm strut would 55 strut brakes fit ? as I have looked at mine strut shouldn't make any difference, am I right ?
  20. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,753
    354
    Mk4 Golf, Mk1 TT and 8L S3... not 8P S3.
  21. Johnny Bravo
    898
    69
    The problem is not with the brakes, is with the hub. 1.9 TDI, 1.6 MPI/FSI, some 2.o FSI have the caliper carriers and hubs in one piece. For bigger brakes (disks) you need other carriers (and calipers). Since they are built in the hub, you cannot replace them, you have to change the whole hub.
    This brings up another issue, some of the cars with this type of hub also come with the 50mm struts. I do not know which ones. I know for sure that there are models with the 2.o FSI engine that have the 50mm struts and others with the 55mm ones. I do not know for the 1.9 TDI.
    The idea is that first you should check if the carrier is built in with the hub or attached to it with bolts. If it is attached, than is only a matter of taking them off and replacing with the new ones.
  22. Cozza McA
    410
    73
    Ok thanks johnny, I follow what you are saying.
    I went into the dealer and on ETKA the picture looked like the disc was just attached with bolts, I know the software isn't a 100% accurate.. And the guy couldn't help as they wouldn't put anything other than standerd on the carAlso the
    price is much and such the same as second hand 312mm
