I'm running Revo stage 3 software and the CTS Turbo K04 kit, and the S3 brakes are fine for my needs. If I tracked it then I'd be looking at the Vagbremtecnic solution.As @curlo said, these aftermarket setups are really excessive for anything but the S3 or above. I think even on the S3 up to stage 2+ the brakes just about keep up. Our diesels or TFSi engines won't make 350+ BHP and if they are I'm sure that person will invest in brakes up to the job lol.
You should try the standard 2.0 TFSI brakes then...the front discs are the same diameter as the S3 rear discs and really are not up to the job. I decided to upgrade the brakes when I joined a roundabout much quicker than I would have preferred, all because the original brakes had wilted...S3 brakes are **** on stage2 + you get real quick brake fade and judders like mad. I'm looking for the rs3 set up for my S3
What do you need in the conversion?
Carriers?
Hoses?
Dust guard?
What is the size difference in s3 and tdi170 brakes?
Hello.
I have tuned PD140, upgraded to 312mm brakes and after some spirited driving on highway saw dark lines on brake disk, also there arose a need of better brakes. What mods should I do without increasing disk diameter (need to suit 16" rims) to increase braking power?
How much better are the s3 brakes over upgraded discs and pads on 312mm
