Big wheels
dublinS4 Sep 11, 2011
  1. dublinS4
    dublinS4 Member
    53
    Hi all
    Would 19inch wheels with235 35,s go on my s4?I will be fitting either eibach or h&r springs(only). Do i need coil overs to do this?
    cheers
  2. aragorn
    18,022
    718
    should do, exact fitment is offset dependant, but they should go on with the right wheels.
  3. mike-a
    mike-a Member
    103
    I've got 19x8 et25 and 235/35 rear and et33 and 225/35 front but on a fwd chassis.This is just on sport springs so not low.Probably got about 25mm arch gap at the rear and 35mm at the front.The wheels sit mor or less flush with the arches.
  4. dublinS4
    dublinS4 Member
    53
    nice one lads...
  5. Rallyman
    Rallyman LPG Abuser & have VAGCOM Bronze Supporter
    213
    As Aragorn says....."You will need to check the offset" ......
    I have just tried to fit a set of 17 x 8.5J ET50 wheels with 245x 45 17 tyres on my QTS. I dont know if the S4's arches compensate bigger wheels ?!
    On mine, with the above wheels fitted EVEN with a 15mm space on the back the tyre was still touching the upper rear arm and the tyre was starting to stand out like a sore thumb from the wheel arch!
  6. aragorn
    18,022
    718
    245's are a little wide TBH and at that width the height (45) is too big, and ET50 is too high.
    I suspect if you dropped to a 225/45, or maybe a 235, you'd get them on with some careful spacing.
  7. dublinS4
    dublinS4 Member
    53
    Im gonna leave it and go 18s.RS4s to be exact.Thanks again chaps..........
  8. Geeman
    Geeman Low Life
    1,318
    If you're going GENUINE RS4's, then you'll have to be careful with the tyre choice as the rims poke out a bit, when compared to standard A4/S4 rims...
  9. Abb
    Abb Member
    309
    I have 19x9j allround, fitted with 235/35/19. lowered using H&R springs -30mm, and they are absolutley no problem!
  10. aragorn
    18,022
    718
    Your sig also suggests you have a B6...
    Ben_Lucas43 likes this.
