big turbo?
b5boy Oct 6, 2012
  1. b5boy
    b5boy New Member
    24
    hey guys i was just wanting to know whats the best big turbo upgrade to go for i have a a4 b5 1.8t all standard but want a bigger turbo i was thinking t3/t4 but wasnt sure on what was best to go for if anyone could give me any thoughts will help alot
  2. aragorn
    18,578
    868
    Define "best"!
    You need some goals first. Whats best for you wont neccesarily be best for me or anyone else.
    Personally i suspect a T3/T4 would be hugely laggy on a 1.8T and wouldnt really be very nice to drive.
    A GT28RS is likely a good fit for the 1.8T that wont be too laggy, but will offer something like 320-350hp.
    Another option might be a T3 60trim from a Sierra Cossie 4x4, similar in size to the GT28RS but a bit less efficient, should do 300-320hp.
    Ofcourse if you have lesser power goals then a different set of options would be there, and similarly if you want 500hp then it'll be a different set again.
  3. b5boy
    b5boy New Member
    24
    I would like 300/350 so the gt28rs sounds like the one would it be safe running a gt28rs with a stock engine the last thing i would want is to stick one go down the road and blow the engine
  4. Sulli79
    Sulli79 Active Member
    541
    37
    Rods would be on the list for me personally, probably intergrated engineering ones.
  5. b5boy
    b5boy New Member
    24
    Would it be safe to run standard rods
  6. Bradderz_1988
    3,982
    261
    Id be putting rods in if your over 260hp as i wouldnt want to run the risk of bending one or even letting go and going through the block.
  7. b5boy
    b5boy New Member
    24
    Cool ok thanks for the feed back ill prob just play it safe for now and get a k04 then think ill go big when i have the cash what's the turbo u got in yours bradderz
  8. Bradderz_1988
    3,982
    261
    Its a hybrid K04 from frankenturbo but it has slight shaft play so its not getting tuned yet its on stock map got a big list of jobs to do first getting it mechanically sound then im going to be looking into doing a engine rebuild with rods/pistons or may even look at a 2.0 stroker kit but thats going to be a work in progress. I wouldnt even get a K04 before a BT i would do it right first time i sort of regret going hybrid and should of gone straight to a GT28 but we learn from our mistakes i guess but i will get there one day with the car lol
  9. b5boy
    b5boy New Member
    24
    That's cool which would u says best a k04 or a hybrid k04
  10. Bradderz_1988
    3,982
    261
    Hybrid will be best option with supporting mods ie 3inch maf 3 bar fpr injectors fmic you should see 260-280hp depending on turbo size, frankenturbo have recently released the F21 longitudinal which has a slightly bigger compressor wheel than the F4 i have fitted, it really is a good bolt on package for just under 1k
  11. b5boy
    b5boy New Member
    24
    Thats pretty sweet that then ill go and have a look at frankenturbo see what they got would audi s3 or tt injectors be sutable
  12. Broken Byzan
    13,237
    465
    The search for power is a long and expensive route to travel. Be aware other componants will wear out quicker too.
  13. Broken Byzan
    13,237
    465
    Depends what engine you have installed, if you have a DBW APU engine then S3 / TT injectors are fine, if it's an AEB you will need to use some bosch redtops or similar
  14. b5boy
    b5boy New Member
    24
    Ill prob have to go with the Bosch ones mines a AEB what size cc injectors would suit that
  15. Broken Byzan
    13,237
    465
    depends on turbo/MAF and tuner choice tbh
  16. b5boy
    b5boy New Member
    24
    Ill just the guys were Im getting the turbo from see what they recommend
