Big Turbo Build Coming Up
Brodster Sep 30, 2013
  1. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,553
    896
    Hi all. Need to pick the 8L gurus brains for 5 mins especially those that have done a BT build. Now I have done a little research and its a minefiled so I would rather get the info from them in the know-how.
    Now a good mate of mine is just about to start the initial rebuild on his 03 plate 8L S3 and as he is away in Kuwait I've been given the task of doing the shopping for some goodies. Now I have been speaking to Jardo as he is quite clued up on stuff to buy and where to get it but tonight it has all changed again so Im after good contacts to buy the goods below.
    1. IE 20mm steel rods - rifle drilled including ARP 625 bolts
    2. ARP head bolt set with installation tool
    3. ARP crankshaft main bolts with installation tool
    The turbo was going to be the LOBA LO320 upgrade but due to differences I think hes now looking at the Garrett set up due to it being more effective at gaining power as they come with a high flow cast manifold.
    Anyone know the best place or person to get Nos 1-3. Any descent info or will gen greatly appreciated.
  2. superkarl
    superkarl MAN OF STEEL
    9,611
    2,481
    lol @ jardo.
    Bill@badger5 is a uk source for IE parts, or there is INA engineering.
    ARP stuff it would be a case of some phoning round. Just to let you know that most if npt all forged rods come with ARP 2000 bolts, the 625 series stuff is some serrrrious hardware, for the most extreme builds (people stretching the 2000 at high rpm misshifts) so prob worth sticking with the big end bolts that come with rods.
    I sourced my rods and bolts through pagparts.com, but expect about 25% on top of the US$ retail
    As for arp mains, the cheapest source of theae are listed for a bmw (same arp part number, i cannot remember the bmw engine code, that aint my thang) , a search should reveal a part number and link that andrew@ald posted. And thats it all sorted. Cheapest and easiest sources :)
  3. superkarl
    9,611
    2,481
  4. <tuffty/>
    21,897
    4,206
    You have been getting advice from Jardo??? oh dear ;P
    Bill @ Badger 5 is an IE dealer and normally has the rods in stock (ARP 2000 bolts... not sure why you want 625's).... he orders from IE quite regularly so can get the ARP mains and head bolts too...
  5. Andrew@A.L.D
    3,879
    617
    625's are a bit over kill for most people on this forum
    even I still use the 2000 bolts without any issues
  6. slowcoach3
    slowcoach3 Active Member
    880
    106
    43
    Jardo, Big turbo? Ko3s then....
  7. Sam_
    Sam_ Down under
    3,038
    480
    Seems to be a bit of a shortage of the BMW mains currently. Mine were on back order from Summit, cancelled and ordered with IE, only to be told there's a wait :(
    I went with ARP:
    - Head Studs
    - Main Studs
    - Flywheel Bolts
    - Crank Bolt
    - Cam Pulley Bolt + Friction Disc
    Also worth looking at the Crank Pulley Dowel Kit:
    1.8T 20V Timing Belt Gear Dowel Pin Kit (06A BLOCK)
  8. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    You guys do make me laugh :beerchug:
    If only you knew :)
    Brodster likes this.
  9. Brodster
    3,553
    896
    Cheers for the info guys. All the spec and items are what he is after so seeing as hes paid me lots of dosh from over in Kuwait I need to get my a55 in gear and start sourcing everything for his return. Maybe he just wants to play it safe and have the best of everything.
    16Klappe likes this.
  10. 16Klappe
    5,795
    1,187
    Bill is a good shout as I said before, that said I have text Alex Kerr your number so expect a phone call today.
    Alex has just replied; 625's are a special order in most rods because they have to be line bored and come with the bolts in situ.
    And I know how much of a deadline your friend has. :)
  11. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    :tocktock: Jeez that dowel kit is laughable money... cost me £3
  12. Andrew@A.L.D
    3,879
    617
    It's also worth using the friction plate on the flywheel also or double dowl the flywheel to the crank
    Sam_ likes this.
  13. badger5
    9,603
    2,061
    so do I.... 600+bhp...
    not an issue
  14. Sam_
    Sam_ Down under
    3,038
    480
    Wish I had all the tooling and bits to do it. Otherwise it'd cost me the same heh.
  15. Sam_
    Sam_ Down under
    3,038
    480
    You mentioned an OEM one before? Have the part number to hand?
  16. Andrew@A.L.D
    3,879
    617
    Yes but i looked into that a bit more and found that it wouldn't work the same as the IE plate
    Double dowel the crank to the flywheel is cheaper
  17. Brodster
    3,553
    896
    Cheers to Bill @ Badger 5 for coming up trumps for me.....highly recommended by Jardo too. Tuscon Rod kit and bolts, ARP head stud kit and main kit ordered.
    Will keep you all informed and pictures of the build when it happens.
  18. Andrew@A.L.D
    3,879
    617
    Is it at about 800 bhp+ when 625's are needed
  19. Sam_
    Sam_ Down under
    3,038
    480
    Yeah, as above it would be if I worked in a workshop or had the tools but alas I don't have either so the friction disc is probably cheaper for me than the labour to get the flywheel and crank dowelled.
  20. aragorn
    18,611
    871
    Friction disk and dowel pins for the flywheel?
    What are you expecting some dowel pins to do that 6 bolts cant?
    I've heard of dowelling the crank pulley before, but thats beacuse people dont tighten them properly and they slip... I really cant see what dowelling the flywheel can achieve?
  21. Prawn
    11,677
    3,676
    I have one of those friction discs installed on mine, almost certainly overkill at my sub 400 level, but it was a present :laugh:
  22. badger5
    9,603
    2,061
    I am very safely short of that... lol
  23. badger5
    9,603
    2,061
    big power 1.8t's... and I mean big power drag ones, have chucked their flywheels off..
    staggering as it may seem.... heard of several having suffered it.
    lots of revs, dumping the clutch on launch...
  24. aragorn
    18,611
    871
    Yeh fair enough, all seems a bit overkill for the build mentioned in this thread though i'd have thought?
  25. Sam_
    Sam_ Down under
    3,038
    480
    Perhaps but it'd be a much more costly repair if the flywheel took out the crank.
  26. Andrew@A.L.D
    3,879
    617
    For me to dowel the crank to the flywheel cost me nothing. I have seen some ARP flywheel bolts come loose making the flywheel move on the crank destroying the flywheel and crank. ARP flywheel bolt on mine have been torqued to 80 lbs/ft and some have stated lower
    For me it was worth it coz i could do it for nothing rather than pay for a friction disc from IE
    Good info for flywheel bolts here
    VWVortex.com - ARP Flywheel bolt Torque spec
    You can see my set up in there too
  27. badger5
    9,603
    2,061
    yep
    agreed
    crank pulley however I would do... especially if it receives a head build with uprated springs
  28. <tuffty/>
    21,897
    4,206
    The IE one are EKagrip friction discs... and I quote..
    I am using an EKagrip washer and ARP bolt for my cam pulley as the supertech springs and eventually cams will add load to a potentially weak OE fixing... have seen cam pulley keys ripped off by using a spanner on the cam pulley bolt to turn the engine over before... seems sensible based on my spec...
