Big Problems, Help Needed, Auto problems
GlennMr2 Jun 30, 2010
  1. GlennMr2
    GlennMr2 New Member
    Hi all
    i give you a run through of my problems, first of all my car is a 2003 1.9TDI multitronic,
    here it goes
    just after feb time my rear brake lights used to come on randomley when parked up but a quick couple of pumps of the brake pedal would turn them off, the problem got much worse untill they wouldnt go off at all and also my esp light would come on and could only be turned off by switching the engine off, anyway to make things worse the ABS light started coming on with it as well, but everything seemed ok , i was thinking its just a new brake light switch is needed,
    But then my problems got worse, i was driving home last night when all of a sudden it was if the car went into neutral there was just no go and all revs, the eng mang light came on as well as esp and abs, i switched the engine on off and back on again and everthing was ok.
    went out this morning and got myself a new brakelightswith from audi which has fixed my brake light problem,
    took her out for a test drive and she broke down again, same problem all auto gears went and could only rev the car, but this time it came up flashing on the dash "ABS FAULT, CONTACT DEALER" or sumin along those lines,
    can an abs fault realy cause all my auto gears to go ???
    also the P,D,N,R,S disapeer of the dash, and if i do turn the engine off it wont let me restart for about 10 mins
    any help much appreaciated
  2. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    strange one mate, but of your tourq converter has had it your gonna need a bank loan! unless you got a mate on here who has a new 2nd hand one in his workshop :idea:
  3. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    Get a VAG-COM scan - should advise on the problems.
    Log all the errors then do a DTC reset and see what pops up again.
  4. GlennMr2
    GlennMr2 New Member
    dwfo a strange one, does anyone know of a vag scan man near enfield, north london
  5. blackpool1974
    blackpool1974 Member VCDS Map User
    138
    Multitronics don't have torque converters, Tiptronics (quattro) do though
    Its late but I am sure I am correct
  6. rjm180
    rjm180 Active Member
    581
    34
    To the best of my knowledge you are correct
  7. GlennMr2
    GlennMr2 New Member
    so i take it no one has had any simular problems then, ??
    . is there a way i can clear the fault codes myself
  8. Turkster
    2,811
    54
  9. GlennMr2
    GlennMr2 New Member
    sorted it was gearbox ECU, £200 it cost to repair, job done, they wanted 950 for a new one
