Big Knob (From a 2009 TT) How to
spider74 Apr 25, 2012
  1. spider74
    spider74 Member
    109
    10
    Sorry couldnt resist the title! My DTM came with a very tired looking Alcantara Gearknob and steering wheel, The alcantara had become almost smooth leather and felt pretty grubby. Using the advice from places like detailing world i had limited success in restoring it by wrapping a hot wet kitchen towel round the areas allowing to soak and then carefully brushing with a small wire detailing brush however it nevere really looked good. here is the before
    Here is the new Gear Knob
    Now to remove the leather gaitor you need to manouver the gearstick to allow a bit of slack on the corner you are starting with and feel through the leather for the four clips which are stopping it from being able to be pulled up. Once you feel these you can carefully release them one by one using your fingers unlill the leather and chrome surround can be lifted up over the gearknob allowing you access to the spring clip seen here.
    Ues pliers and a small screwdriver to burst this clip off and then the whole lot will lift off. (you will use a small hose clip to replace this or worst case a cable tie done up super tight)
    then you need to remove the leather gaitor fro the old gear knob. ( i wish id taken pics of this bit but will try again) the leather is held on by the plastic bayonet fixing under the knob. you need to twist this until it releases allowing you to remove the knob from the leather. then the reverse to attach it.
    make sure you line it up the right way up and its all nice and neat. then slide it onand use a hose clip to secure, fold the leather back down and your done.
    It feels and looks much better IMO and matches my retrofit B8 S-line steering wheelo with the chrome inserts
    the entire job took me less than 15 mins including trying to find my pliers at the bottom of the tool box.
    you can get a good used gearknob on ebay for about £30 and the B8 WHeels are readily available as many people upgrade to the flat bottomed version. I like the look/feel of the newer ones and its made the interior a bit different which after all is what modding is all about :)
    hope this helps someone have the confidence to go for a change
    Adam
  2. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    2,027
    800
    Looks really good, great match, have you got a link fella. Is it OEM or aftermarket.
    Mac
    Ah would you believe found one on the bay, cheers big knob lol
  3. ANDYTQ
    ANDYTQ Well-Known Member
    1,186
    106
    I changed my a3 one for a beetle sport one thats a nice one too.
  4. Macdoon
    2,027
    800
    Do you have a pic
  5. ANDYTQ
    1,186
    106
    Not sure and car is gone.
  6. amar06fbr
    amar06fbr Vorsprung Durch Technik
    1,055
    68
    :icon_thumright: great mod!
  7. spider74
    spider74 Member
    109
    10
    thanks :) the knob was a Genuine OEM from a 2009 TT. fitted on perfect and sits about an inch lower than the stock one giving a kinda short shift effect.
  8. razza1
    razza1 Well-Known Member
    3,077
    831
    Looks good. Leather cleaner and a micro fibre cloth worked well on my old one. They were a pain in the **** to keep clean though.
    Much prefer my rs4 one, much less cleaning.. .
    Sent from my HTC Incredible S using Tapatalk 2
  9. spider74
    spider74 Member
    109
    10
    yeah the RS4 genuine one is sweet, but a LOT more cash and very hard to get for decent money secondhand. id like one but this will do for now :)
    for anyone trying this here is a pic of the clips you have to undo and the hose clip i used. might help.
  10. docurley
    4,073
    88
    Nice job
  11. NHN
    29,577
    1,779
    Looks nice, the RS4 one is very nice touch aswell, fitted it to my B6 S4, TT one is larger head which I think is probably better for usage tbh.
