  1. audi-pricey
    audi-pricey Member
    82
  2. Lee_R
    Lee_R Active Member
    2,499
    12
    your bits are correct but the ebay link is to an 09 facelift bumper so no dont buy that!
    When looking on ebay at bumpers make sure there is a support built into the bumper behind the grille, the 09 ones dont have it.
  3. Ads
    Ads License to drive
    8,230
    607
    Does your car already have fogs??
    If so then I don't think you need to buy different ones.
    Thought it was only if you fit an S3 bumper that you need different fogs??
    Could be totally wrong though.
  4. audi-pricey
    audi-pricey Member
    82
    ok thanks lee r i will look out for the middle bit
    the s-line has got different fog grill
    can you fit an s3 bumper and bonnet or do you need wings aswell ??
  5. SteveTDCi
    SteveTDCi Active Member
    1,400
    let me know if you need a grill, i have an sline grill with chrome frame sitting in the garage that I intend to put on ebay in the near future, if your interested £40 delivered and i can post some pictures.
  6. Ash B
    Ash B Well-Known Member
    5,831
    No you dont needs wings mate in less your planning on doing the 09 conversion. If your doing the S3 front end you need a bonnet and S3 grill/bumper
  7. audi-pricey
    audi-pricey Member
    82
    sound well i was think just getting the parts together over time so i might aswell get the s3 parts
  8. audi-pricey
    audi-pricey Member
    82
    if i have got an s3 bumper will an a3 grill fit or does have to be s3 ??
  9. shawy01
    shawy01 New Member
    You will have to get a S3 grill aswell. The grill is about 10mm shorter so the A3 one will be too long.
  10. Ads
    8,230
    607
    Think there is some confusion about whether this is true or not.
    Apparently if you get an early s-line bumper they use the same fog lights as the prefacelift.
    See below quote....
  11. Lee_R
    Lee_R Active Member
    2,499
    12
    theres always confusion as early facelift s lines had the standard bumper which use the same fog/grilles as the early split grille models. 06 on s lines have the smoother bumper with different grilles. If you get an S3 bumper they use the same fogs as the 06 facelift s lines but different grilles.
  12. audi-pricey
    audi-pricey Member
    82
    it is very confusing i want it smooth looking so with out the bumper strips that are on mine at then mine
    the new s-line and the s3 are both smooth so i will just have to make my mind up do you lot think it will look abit silly having a s3 bumper and an a3 ??
  13. Lee_R
    Lee_R Active Member
    2,499
    12
    No its fine, just dont put the S3 badge on the grille!
    If you are going smooth then i think you should put the facelift rear on too, would look odd smooth on the front and then a bump strip on the rear!
  14. Bailey
    Bailey Member
    247
    15
    yeah the S3 bumper will look pretty good ben! guess you are following in my footsteps with the conversion. I am getting mine sprayed end of this week so you will have to call round mate, then i can see how your going with your conversion too.
