big brake kits
20vtdaz Apr 26, 2007
  1. 20vtdaz
    20vtdaz Member
    92
    hi guys im after some bigger brakes for my s3 but the concern i have is that the car is on rs4 wheels and im led to believe they wont fit, is this true and if so what other options do i have, thanks guys, daz
  2. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    Nonsense :)
    You might need spacers though...
  3. joe6886
    joe6886 Member
    241
    What brakes are those Chris? The caliper looks huuuge.
  4. ChriS3
    2,239
    27
    Its the ECS Stage 3 kit. They use 993TT discs and calipers.
  5. 20vtdaz
    20vtdaz Member
    92
    mate they are lush ! ! ! so im assuming you run spacers? thing is i tried some 8mm spacers up front and didnt like the look of them or the fact that they didnt seem safe with out the hubcentric bit, was thinking of wilwoods as they do a slimline version? anyone had any views on them? thanks for comments by the way,
  6. joe6886
    joe6886 Member
    241
    They look awesome, bet there is some stopping power there. Are they 6 pot's?
  7. ChriS3
    2,239
    27
    Porsche/Brembo 4 pots.
    With the RS4 reps I run 16mm spacers at the front. Even then, there's only just enough clearance, less than 1mm in places. With the 8.5x18" et30 BBS wheels I use 10mm spacers. You could get away with 5 or 8mm ones, but I prefer the hubcentric type.
  8. ChriS3
    2,239
    27
    If you're worried about the fit and want better braking, the Brembo GT kit is work looking at. If you want bling, then the ECS kits are good. The Stage 4 and 5 uses Cayenne 6-pots and 358mm discs. Quattronics do good kits with GT3 calipers too. I've not seen any 8mm hubcentric spacers, but I believe H&R do them. Try DPM. If not, go for 10mm.
  9. simch
    simch Active Member
    2,028
    I think smallest H an R hubcentrics is 10mil a side...?
  10. 20vtdaz
    20vtdaz Member
    92
    it was an eibach kit that ive sent back now, but i was told they were, i really want to avoid spacers where possible,
  11. s3_tny
    s3_tny Member
    91
    why not give Quattronics a try mate they do a kit with boxster 4 pots on standard s3 disc and fits fine without any spacers with avus rims and is nearly same size as the brembo 4 pots so brake feel is kept
  12. ChriS3
    2,239
    27
    No need to be so keen to avoid spacers, just keep away from lugcentric spacers. If you lower your S3, chances are it'll look like the wheels are sucked in.
  13. Stewart
    Stewart Member
    705
    10
    I've just fitted 996TT (GT3) calipers on R32 disks and have to run 15mm spacers on MTM reps (35mm offset) although could probably get away with 12-13mm spacers if I could get hold of them...
  14. silver75
    silver75 Big Ron
    3,265
    I have 8mm hubcentric H&Rs think i got them from Damian
