Big brake kit..
SteveBAM Oct 27, 2009
  1. SteveBAM
    SteveBAM Black '03 S3
    180
    hi I am in the process of upgrading my front and rear brakes with a big brake kit. I have read about all the useual big brands like brembo, Porsche kits and others., but have not found any info on CompBrake kits. I find there 4pot 350x32mm ( http://compbrake.co.uk/shop/product_info.php?cPath=1&products_id=3634 ) is selling at a very good price compared to all other big brake kits. Has anyone used this kit? it would be very interesting to have some info from anyone using this kit..
    cheers:beerchug:
  2. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,824
    107
    Ive not used these but i too am looking at upgrading my rears .
    Im doing my own kit using S4 rear discs. i will be redrilling th PCD to 5x100 and then machining some caliper mounting brackets to lift the caliper out to sit correctly on the bigger disc.
  3. Dani_B19
    9,167
    363
    Can you get a 2 piece disc set up for the rears? Either the same size as standard or a little larger?
  4. S3 Paul
    2,824
    107
    You can.
    ECS do one i think Jojo's car has them
  5. Dani_B19
    9,167
    363
    Didnt know jojo's were 2 piece.
  6. SteveBAM
    180
    CompBrake has a 333x20 2 piece vented kit for the rear using the OEM caliper, but I think that might be a little to extreme..
    don’t know about the rear, but ill probably be going for the front 350x32mm kit that has 2 piece rotor at a very attractive price..
    and by the looks of things ill probably be the first one trying them..!!:unsure:
  7. jojo
    28,856
    3,516
    My rears are 2 piece disks with spaced out standard calipers. I did it for looks than performance, it's overkill, but hey, my car stops pretty well, and some say the rears look bigger(308mm) than the fronts! lol :cool:
  8. random101
    random101 Member
    130
    im about to put on 355mm xyz brakes
  9. S3Steve
    S3Steve Active Member
    1,612
    17
    Caney over on ttforum.co.uk is running a compbrake setup on his 400bhp TT, might be worth pm'ing him and seeing how he is getting on with them. He previously had a porsche setup iirc so should be able to give you a comparison mate.
  10. SteveBAM
    180
    ok, thanks mate, ill do that..:beerchug:
  11. Dani_B19
    9,167
    363
    Jojo do you know the weight of a single rear disc of your ecs set up?
  12. jojo
    28,856
    3,516
    No, they are a bit lighter than the OEM rear disks if I remember correctly, nothing major on weight saving. As mentioned before, it's more bling than performance, unless you have Big Turbo power.
  13. Dani_B19
    9,167
    363
    So defianetly lighter then? I just want them for the weight saving aspect more than anything, cant afford togo BT now for a while :crying:, my savings have took a big hit due to people not being able to drive
  14. jojo
    28,856
    3,516
    Ever so slightly, the ECS items are bigger remember, I would say they weigh almost the same so little is the difference.
