Big brake conversion
tonyjohnson Oct 19, 2009
  1. tonyjohnson
    tonyjohnson New Member
    23
    evening, just a quick one. I have a 2002 audi a3 quattro sport (6) i am looking for a good brake upgrade as the standard items are poop. i have bought a whole front subframe from a 2008 golf r32 will all the items just swap over onto my a3 ie calipers disks and stuff.
  2. Dani_B19
    9,382
    403
    Someone will prob's correct me, but no,the stud pattern the r32 will be 5x112 were as your a3 is 5x100, so discs will need tobe re-drilled, you'll also need new custom brackets for the calipers etc.
  3. tonyjohnson
    23
    thanks for the info, i think i will have to buy a mk4 golf r32 setup then
  4. <tuffty/>
    21,885
    4,204
    As Dani has said, 2008 Golf is a different setup to the Mk4. You biggest prob in all honesty will be the weight of the calipers and the expense of the replacement discs as they aren't cheap. They are 330 x 32 IIRC and have a 'moulded in' alloy bell so have to be replaced as a complete unit and there are no aftermarket/cheaper alternatives I currently know of so you will have to pay their prices to replace them.
    If you are after big brakes on a reasonable budget then you could try a similar setup to mine.
    I bought these calipers from ebay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250455042455
    They are AP Racing calipers (CP6600) that just have TVR on them rather than AP Racing. Might be an idea to give the guy a call as he still has the item on ebay but I have heard he may have sold out.
    Brackets can be got from Badger 5 for £120+vat and Bill also has brake pipes and DS2500 pads to go with these calipers too.
    I used a 330mm 2 piece setup which is expensive but you can save money by using 323mm Leon Cupra R discs (323 x 28mm) which you can either pick up as an OEM type replacement for around £80 or go for something fancier for more.
    Paint the TVR logo black like I have for the stealth look ;P
  5. Broken Byzan
    13,237
    466
    Mk4 R32/Anni /S3/TT, all you need are the carriers as the calipers themselves are the same and the 312mm discs
  6. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    mk4 r32 are 2 pot calipers so are different to s3/tt/anni.
    i done all this mucking around looking at what brake combo to go for but ended up going for the trusted brembo and ds2500 pads and im so glad i did it awsome, also tufftys set up looks bloody good at a decent price
  7. <tuffty/>
    21,885
    4,204
    ...they work bloody good too... stoppage++
  8. tonyjohnson
    23
    morning sorry for the delay in replying, i have got myself a 330mm setup using 911 front brembos i will put some pics up a bit later today.
    :hubbahubba:
    i have used alfa brera disks re-drilled to 5x100 330mm x 28mm have goodridge hoses for brembo to a3, and textar 4045's as pads selection which is porsche oe.
  9. will.f_1.8t
    will.f_1.8t Member
    114
    tuffty, does this mean you have your original s3 carriers for sale, if so i would be very interested!
