Bi-Xenon Manual Adjust - Continental
MilkDawg Feb 8, 2013
  1. MilkDawg
    MilkDawg Member
    50
    Hi guys, have had a search but can’t seem to find much - I’m guessing because 99% of people have auto leveling with these!
    Anyone know of a way to change Bi-xenon’s over for continental use manually?
    I have looked inside the headlights and can’t seem to see anything obvious. I know people with the auto leveling can apparently do it via VCDS, which says to me that I must be able to move/adjust something manually from inside.
    Thanks for your help!
  2. monopole
    monopole Well-Known Member
    1,154
    470
    Done through the DIS, with the engine off but ign on I think?
    I know I can do it via the RNSe MMI
  3. NHN
    29,561
    1,778
    You cant change any light settings via the rns-e, through the dis there are some settings.
    There's nothing inside headlights, you have to manually turn the adjustment screws on headlight tops, lower the beam.
    The vcds setting isnt actually a switch from rhd to lhd, all it does is lowers the beam & when turned of again, raises it back.
  4. MilkDawg
    MilkDawg Member
    50
    Ahh, that makes sense. So there is no way to have a proper coversion, thanks for clearing that up!
    Many thanks.
