Bi-Xenon Headlights Flickering Issue??
S4P4UL Jul 31, 2013
  1. S4P4UL
    S4P4UL Member
    82
    As the title really, sometimes I get a flickering issue with the headlights, not always just sometimes. maybe 6/10 times it will flicker for 15-30mins of the drive, not constant flickering but a flicker then maybe 5 mins after another flicker? any one else have this problem??
  2. ricostuart
    ricostuart Active Member
    409
    43
    very common problem tbh. Two possible faults - bulbs or ballast. If ballast, its stupidly expensive. But, its more likely the bulbs. My s4 had the same problem that it randomly flickered but was fine more often then not. Changed the bulbs and its been perfect ever since.
    Get some new bulbs and you will be fine!
  3. NHN
    29,300
    1,702
    As above tbh, try turning them of then on again & see if the issue goes, usually bulbs, but be careful buying cheap tat as the ones I had of hids direct were a nightmare, prolonged usage they started not turning on again, then the 6k vision was terrible, bought the real McCoy from hids direct & havnt looked back since, great vision & not one flicker.
  4. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Had this issue last year, changed the bulbs and upgraded to 8000k (I preffered the blueish light output) from Trups and problem solved!
  5. S4P4UL
    S4P4UL Member
    82
    Has anybody got a link to where I can buy they from? Is there a big difference between OEM and 6000k?
  6. psychopomp1
    psychopomp1 Member
    164
    14
    If you want the very best quality bulbs then buy Philips or Osram bulbs. However DO NOT buy them from the dealership as they are >£100+vat for EACH bulb!!! I bought a pair of Osram Xenarc cool blue 5000k, they are perfect...not blue, more like a crystal white and they make the stock 4300k's look like Halogens! They cost around £100 per bulb from UK or buy them from Germany for 65 euros each from amazon.de
    OSRAM Xenarc Cool Blue Intense D1S (single) | PowerBulbs
    Osram 66144CBI Xenarc Coolblue Intense 12V 35W PK32D-2 Kraftfahrzeug-Lampe: Amazon.de: Auto
    EDIT: cheapest i can find them in UK is £85 but still cheaper to buy them from Germany
    Replacement Osram D1S Cool Blue Intense Upgrade Cool Blue Intense...
  7. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    438
    I would try bulb first. But change the pair if you can. I got pair of OEM 4300k for £75 on ebay
