Bi-xenon headlights coding Manchester
Heisenberg Jun 13, 2012
  1. Heisenberg
    Heisenberg Member VCDS Map User
    67
    Please can someone help with the above for cash or beer :)
  2. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    have you got the codes?
  3. Heisenberg
    67
    Euro Headlights & DRL
    Module 09 (Central Electrical), recode to ###21
    i think the origininal code for the halogen is 01012
    If u have the code 21 then the lights work but if not the hight beam then you have connected the small yellow pins wrong. i did it to after changing it it worked like a charm :D
  4. Heisenberg
    67
    From all the threads I have read the above are the codes to use.
  5. Heisenberg
    67
    Evening,
    After a bit of advise, I tried to code the headlights today and struggled to change the code tried 00021 as the coding was 00001 and it still reverted back to 00001. Also tried other variations eg. 01021 and 01031.
    Not sure what to do, the lights come on okay but on high beam the drls light instead.
    Kind regards,
    Paul
  6. NHN
    29,417
    1,740
    Your CE module maybe not compatible with the coding, so may require an upgrade.
  7. marv
    marv Member
    272
    this is what mine is doing, you need the module mate
