Bi Xenon flickering on start up! whats usually the problem?
Ashley Martin Feb 19, 2013
  1. Ashley Martin
    Ashley Martin Member
    57
    Hey guys
    As the title says what could be wrong, its a 57 plate S3 and I just noticed that when I put the ignition on it was flickering, but then cleared after a few seconds. Its like its only on fire up!
    Ash
  2. NHN
    29,282
    1,692
    Could be a bulb or headlight module, is it one side or both?
  3. Sidhu88
    Sidhu88 Active Member
    808
    76
    By any chance does it do it around if not exactly 5 times? I get this with my led 501s. Im sure its just the canbus system passing power through to make sure all is working well, although thats aftermarket equipment i doubt the same thing should happen with oem?
  4. NHN
    29,282
    1,692
    Not with oem bixenons no.
  5. Ashley Martin
    57
    It's just on the passenger side and it is more like a slight flicker rather than a strobe effect!
  6. Ash187
    7,438
    701
    most likely bulb is on its way out
  7. essIII
    essIII Active Member
    285
    35
    When my Xenon bulb started to die it produced a noticeably purple light in comparison to the other one which was still more blue/white - is there any difference in the colour of light between your passenger and driver side lights?
  8. Sevv
    Sevv Pushing the limits..
    1,321
    118
    try the bulbs mate most likely or the ballast but i would change the bulbs first
  9. Ashley Martin
    57
    I haven't noticed any difference in the colour of the light and after the first start of the day it seems to stop until its left again for a while. How much is a bulb for these?
  10. Sevv
    1,321
    118
    i bought mine of ebay 100 USD i remember.... , i remember one of the member had an issue with the headlight switch in the cabin , check the connection to the switch is fine too
  11. S3Alex
    S3Alex Rarely neutral Team Ibis Audi S3
    10,287
    4,349
    From your friendly Audi dealer the bulbs are about £120 and the ballast will make you weep.
    About £600.
    Mine packed in a month ago.
  12. essIII
    285
    35
  13. The Governor
    The Governor Active Member
    498
    72
    £600!!! How can it be that much?? Is it that the ballast is not a consumable and in theory should never go, or is it an inevtibality that it will at some point, because £600 to get your headlights working is obscene...
    [Edit] Ah I see, just did a bit of a check about, ballast is not ballast at all, it's a voltage regulator...
