Bi-Xenon Fault
RobinA3 Aug 19, 2010
  1. RobinA3
    RobinA3 Well-Known Member
    1,828
    47
    Recently my drivers side headlight has been flickering and now it turns off itself and comes up with 'dipped beam fault' on the DIS.
    If i turn the lights off and then on again it fires up but then dies again pretty much straight away.
    Anyone had the same issue?
    I am dreading on having to spend stupid money for either a new control unit or a bulb!
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    what does vagcom say? I'm sure if you dont mind fleabay etc the bulbs are too bad, its the controller for Bi thats bit rarer & more pricey.
  3. RobinA3
    1,828
    47
    not had chance to vagcom it yet, hoping its the bulb but knowing luck it will be the control unit.
  4. chrissy1502002
    chrissy1502002 Member
    238
    I had the exact same problem with my drivers light, and less often on my passangers. I changed both of the xwnon bulbs and hey presto problem solved. When i took the old ones out there was "****" in the little gas chamber, which i beleive was causing the problem.
    Euro car parts do the bulbs for about £70 each and they are genuine philipps ones.
    Hope this helps!
  5. Synchromesh
    Synchromesh :-)
    98
  6. NHN
    29,521
    1,765
    Sounds like bulb to me mate, £50 set on ebay 6k & work no worries.
