Bi Xenon bulb replacement.
Mr-C Nov 16, 2013
  1. Mr-C
    Mr-C Active Member
    234
    Looks like I have lost the drivers side bulb, not flickering just dead! Thing is I know its a D1S bulb but does anyone know what the OEM spec is?
  2. lynallbel
    lynallbel Active Member
    395
    No sorry i dont but from experience of changing merc D2R type xenon bulbs, get a black marker pen and mark the retaining ring as they are a real arse to line everything back up without it all falling out!
    Might be worth swapping the bulbs over as it could be the control unit thats gone tits up
    Lynall
  3. rizzini7
    rizzini7 Active Member VCDS Map User
    965
    146
    43
    D1S Phillips 4300k I believe
  4. Mr-C
    Mr-C Active Member
    234
    Fecking bulb working this morning briefly!! Must be a ballast problem
  5. Mr-C
    Mr-C Active Member
    234
    After muchio ball ache I managed to swap the bulbs and the problem didnt swap sides so it is the ballast
  6. rizzini7
    965
    146
    43
    Is it the adaptive xenons?
  7. Mr-C
    Mr-C Active Member
    234
    Yes they are adaptive xenon's.. It started working last night and stayed on for an hour or so drive, tested them this morning and I still have 2 working lights!! I have a self fixing car.
    I purposefully kinds went for bumpy roads to see if it caused any flickering but nothing.
    I did wash the car yesterday and I did wash the slam panel and up the insides of the top of the wing. Makes me wonder if water has made its way somewhere where it should not?!
  8. lynallbel
    395
    Maybe a dodgy joint on the wiring loom?
  9. rizzini7
    965
    146
    43
    I had to swap one of my headlights out due to a similar issue. Swapped the ballasts and the problem stayed on the same side. When I sold the headlights for spares the lad took it apart and the motor had come loose. So I'd try swapping ballasts first. Awkward I know
