bhp gains from exhaust!!!!
chrisa4quat Jan 6, 2007
  1. chrisa4quat
    chrisa4quat Active Member
    970
    29
    Are there better exhausts that give better gains (tho minimal) or are they all about the same????
  2. Ess_Three
    Ess_Three Active Member
    5,383
    I'd say you'll get better gains from some than others...
    Probably varies between absolutely nothing to maybe 3-4BHP if you are lucky.
  3. Boydie
    Boydie Guest
    full turbo back exhaust system from the likes of miltek
    larger down pipe, decat and rear back box should see gains of around 3/4/5 bhp as said above
    can be expensive - anything from £350+
  4. smogthemog
    smogthemog Member
    42
    If you remove the cats in your exhaust system, is there anything else to do to the car afterwards - Vag-com, Lambda ?????
  5. Ballcrusher
    Ballcrusher NO CAT JUST 3" STRAIT THREW
    347
    removed the cats on my S3 but was luck as i have a 2000 x reg and dosent av second lamda
