BG44K fuel additive
Fenriz Oct 10, 2013
  1. Fenriz
    Fenriz Member
    84
    14
    Hi guys, just had my car MOTd and was recommended putting a can of BG44K additive in with the fuel, wow what a difference. No black smoke out the back when hard accelerating, and the power comes on smooth, before the engine seemed to pulse while accelerating. Also seems more responsive.
    Anyone else use this?
  2. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Used it in the past, it seems to do the job. They recommend to use it once a year.
  3. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,234
    386
    I used this on my 8L S3 and it did what it said on the tin. I recommend it.
  4. mramage
    mramage Member
    516
    Another vote for it here. Made a noticeable difference on 2 out of 3 cars I tried.
  5. Minstadave
    Minstadave Member
    560
    19
    Bg44k is for petrol engines isn't it? I though bg244 was for diesels.
  6. Napbree
    Napbree Member
    136
    13
    Didn't know about this, just ordered a can from amazon - £23, if the reviews are anything to go by then I can't wait to get it in my car!
  7. Minstadave
    Minstadave Member
    560
    19
    You can usually get it for £15 off eBay.
    I've used it 3 times I think in the last 60k, no appreciable difference to be honest, wouldn't get too excited.
  8. excelon53
    excelon53 Member
    Has anyone tried sucking some of this through the intake manifold to get the backs of the intake valves? Kind of like Seafoam, only it actually does something :icon_thumright:
    I'm curious if it's safe to do?
  9. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    Mines been great since using it! Tfsi and no more bogged down cold start and more responsive great stuff for 20 quid!
  10. excelon53
    excelon53 Member
    Did you just do the BG44k in the tank or did you do some BG ISC through the manifold as well?
    The BG44k in the tank helped me a lot, I couldn't believe how noticeable the idle changed, less jerky at low RPM and more torque at low RPM. I think I'm missing power up top still which leads me to believe valves are still a bit gummed.
  11. OVRA3
    1,079
    80
    I just used it in the tank, i did it when I was just doing short journeys so it lasted ages in there. It's not perfect no substitute for proper clean but if it helps with the jerky cold starts then it's not all bad.. Unfortunately mines now developed a knock when changing gear :-( just when I though all was well lol
