as my new car came with nothing but a v5 i thought id check when mot ran out on the .gov website
all i can say is wow it was allowed to leave testing station
all the stuff in red ive already sorted and i was about to put it in for a test but i think ive got a bit more to do
Reason(s) for refusal to issue CertificateAnti-lock braking system warning lamp indicates an ABS fault (3.4.1d)Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)Offside Windscreen wiper does not clear the windscreen effectively (8.2.2)Nearside Stop lamp not working (1.3.2a)Offside Front Lower leading/inner Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.3)Nearside Front Lower trailing/inner Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.3)Nearside Front Lower trailing Suspension arm has excessive play in a ball joint (2.4.G.3)Nearside Front Front constant velocity joint gaiter insecurely mounted to its housing (2.5.C.1a)Centre box joint Exhaust has a major leak of exhaust gases (7.1.2a)Nearside Rear Brake pad(s) less than 1.5 mm thick (3.5.1f)Offside Rear Brake pad(s) less than 1.5 mm thick (3.5.1f)Offside Front Tyre has a bulge, caused by separation or partial failure of its structure (4.1.C.1b)Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.D.1)Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.D.1)Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.D.1)Offside Front Wheel bolt(s) missing (4.2.1c)Offside Wheel bolt(s) missing (4.2.1c)Offside Front Upper leading/inner Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.3)Offside Front Upper trailing/inner Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.3)Nearside Front Lower leading Suspension arm has excessive play in a ball joint (2.4.G.3)Nearside Front trailing/inner Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.3)Nearside Rear Brake disc(s) excessively pitted (3.5.1h)Offside Rear Brake disc(s) excessively pitted (3.5.1h)Nearside Rear Road wheel bead rim badly distorted (4.2.1a)Nearside Rear wheel bearing has excessive play (2.6.2)Nearside Front Front brake juddering severely (3.7.A.2b)Offside Front Front brake juddering severely (3.7.A.2b)Nearside Rear Rear brake juddering severely (3.7.A.5b)Offside Rear Rear brake juddering severely (3.7.A.5b)Front brakes imbalanced (3.7.A.2e)Advisory Notice issuedFront both Brake disc(s) slightly pitted (3.5.1h)Front bumper insecure
