best way to put mp's onto sd card
Brookie-S3 Feb 13, 2008
  1. Brookie-S3
    Brookie-S3 Member
    68
    hi guys.
    i finaly got my 2gb sd cards and formatted them to fat32.
    which is the best way to add mp3's to them, if i just drop them onto the sd card i can only get about 6 albums on?
    ie. media player or i tunes.
    plus a good description please. bit new to all this.
    thanks
  2. Issac Hunt
    1,162
    Put each album in its own folder on the root of the SD card. You should get more than 6 on it!
    Use something like windows media player to rip your CD's into MP3 - It MUST be in this format.
    You should get approx 20ish CD on each card depending on the bit-rate of the tracks you have.
  3. N8
    17,163
    720
    Thanks Isaac, I'll be sorting out all my SD cards soon as well, ready for when the big day arrives on march 1st...
  4. klauster
    klauster Well-Known Member
    1,188
    112
    if you shop about you can still get 4gig SD cards that work in your car...
    The bitrate is the big thing, I find 192kbps is best quality/size ratio
  5. Brookie-S3
    Brookie-S3 Member
    68
    ye i think thats my problem, most of my music is in 320 bit,
    but i have got a lot more albums on now and it works a treat !
    i couldnt find any 4gig standard sd cards
  6. N8
    17,163
    720
    But no point in 4GB SD cards klauster as doesn't the RNS-E only read the first 500 files anyway???
  7. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Depends on the bit rate you use and the size of each file.
    I use 320kbps bit rate and I get over 2GB of files onto a 4GB SD card before reaching the file limit.
    It appears the limit is 400 MP3 files, within a total of 512 objects (object = folder + MP3 file + M3U playlist).
    Someone on another forum last week said they couldn't find any 4GB SD cards, so I sent them 10 links that I found on Google in less than 5 minutes.
  8. N8
    17,163
    720
    I know, but some people can't help it Dave! Most of my files are 192kpbs and they'll be going in Album folders, so can I expect 20 a card?
  9. J7-AUDIA3
    J7-AUDIA3 Member
    117
    I've tried to find 'Standard' 4GB SD cards and can't find any, maybe I'm slow. Where do you get them from?
    Also need a card reader as my new laptop does not have one, what one is the best?
    :respekt:
    J
  10. J7-AUDIA3
    J7-AUDIA3 Member
    117
  11. klauster
    1,188
    112
    nope dont fink so
  12. Brookie-S3
    Brookie-S3 Member
    68
  13. Nutkins
    Nutkins Member
    66
  14. Brookie-S3
    Brookie-S3 Member
    68
    no i didnt, lol
    but mine works ok and had no problems, just plug in and it works fine
  15. Brookie-S3
    Brookie-S3 Member
    68
    the only problem i have is that i put all into folders, so i had 15 folders as albums
    But i cant choose different folders, the songs are all together, so if i want album 4 on, i have to scroll all the way down ? through 40 songs for example
    is this right ?
  16. Issac Hunt
    1,162
    No you shouldnt have to do that. I have each album in its own folder which is placed in the root of the SD card and this works perfectly for me.
  17. JST_A3
    JST_A3 Member
    99
    If you press the 'Return' button this should take you 'up' a level and allow you to select the album. You should then be able to scroll down the tracks in that album to choose the one you want.
  18. Juniper44
    Juniper44 Member
    47
    Hi, when I formatted my sd card I don't have a root folder come up, its just completely blank when i look at on the pc?!
  19. PetrolDave
    1,559
    85
    That IS the root folder!
  20. Brookie-S3
    Brookie-S3 Member
    68
    thanks for all your help, myn now works a treat i didnt realise i had to press return to see the folders...
  21. PetrolDave
    1,559
    85
    The use of the Return button is NOT well documented in the manual!
