best way to make a start ?.. s3 0-1xx
DaSSSeR Aug 7, 2013
  1. DaSSSeR
    DaSSSeR New Member
    9
    hi would like to know how to start your s3 best? .. has stage 2 +
    and I found it hard to make a good start in it? hope there are some who will say
    how they start from 0 it is about a 2010 manual model
    from
    kasper
    sorry my bad English :D
  2. S3Alex
    10,699
    4,749
    Do you mean how to get the fastest launch/start from 0-100kph?
    The quickest is to hold the rpm at about 4000rpm,select 1st and just sidestep the clutch.
    If you do that a few times you'll end up needing a new clutch ,gearbox and possibly propshafts.
    The other way is to use lower revs(say about 3000rpm) and feed the clutch up as you increase the throttle.
    It's smoother and more mechanically friendly.
  3. DaSSSeR
    DaSSSeR New Member
    9
    how to get the fastest launch..:D its not that easy like the dsg versions it has launche control :(
  4. S3Alex
    10,699
    4,749
    Thought so.
    See what I've written above.
    The fastest method will knacker one or other part of your drivetrain sooner or later.
    The other is a little slower but works pretty well and requires a bit more skill with the footwork.
  5. DaSSSeR
    DaSSSeR New Member
    9
    it would not die because of the low rpm? lose pressure or what it calls. 3000 rpm hmm :p
  6. S3Alex
    10,699
    4,749
    Depends on whether you want bragging rights at the pub or bragging rights at the garage.
    N8 likes this.
  7. DaSSSeR
    DaSSSeR New Member
    9
    :D okay i will give it a try thanks :D
  8. S3Alex
    10,699
    4,749
    The secret is to experiment a bit and see what works best without wrecking your car.
    Try 3000rpm and feed in the accelerator as the clutch comes up then maybe a bit more next time if the car bogs down.
  9. sliced
    sliced Drive safe, stay alive.
    1,557
    334
    maybe turn esp/traction control/ off too whilst lauching? may get wheel spin but won't bog down?
  10. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,404
    544
    Aircon off, windows down, pre launch poo in the toilet for weight loss.
    leeds2592 and RedDejavu like this.
  11. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    Love those pieces of quality advice!
  12. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    Why windows down? Smell that clutch burrrrnnnnnn
    RedDejavu likes this.
  13. RedDejavu
    1,806
    337
    launch in flames and smoke like a boss:blackrs4:
  14. OVRA3
    1,079
    80
    Then break down a mile up the road.. I want dsg next so I can launch.. Even though I know there can be issues everyone should have dsg
  15. S3Alex
    10,699
    4,749
    The same issues are there,apart from the DSG clutch pack which is better than the manual clutch,and of course,launch is automatic.
    You still have to consider how much you like your gearbox,propshafts and transfer case.
  16. OVRA3
    1,079
    80
    So you can't just launch all the time then? I kinda of thought that you could just floor the auto boxes without too much problem? I'm too scared to give mine too much in 1st and 2nd as I'm still on clutch number 1 with a stage 1
  17. S3Alex
    10,699
    4,749
    Put it another way.....yes,you can,but the gearbox is not the car's strongest point.
    You can put a lot of torque through it,and a lot more than it's specc'd for,but as with all things mechanical,the rougher you treat it,the shorter it's life.
    The manual S3 clutch is rubbish,and good for stock power and about 10% more,but the gearbox will deal with around 500lbs,but it does increase wear and shorten life.
    The same applies to the DSG.
  18. OVRA3
    1,079
    80
    When I got the car I would have gone for a manual all day long but I don't find it that smooth and I think when I trade up for the s3 I think ill go dsg but after your comment maybe keep the launches to a minimum 😇
  19. S3Alex
    10,699
    4,749
    It's sensible,if you plan on keeping the car,and also if you modify it,you have to remember the extra loads involved.
  20. sliced
    1,557
    334
    Lols i used to launch my a3 every chance i got at traffic lights :$ still worked fine after a year, but suppose probably because it wasn't that powerful.
  21. OVRA3
    1,079
    80
    Good advice Alex as much as we have a giggle on this forum sometimes I reckon it's saved me a lot of money and headache since I bought my car. Things like haldex servicing that I never knew and failing DVs only found out about through here
    S3Alex likes this.
  22. S3Alex
    10,699
    4,749
    Thats the thing......when you uprate an engine substantially,any margins in things like the gearbox and drivetrain are eaten up pretty quickly.
    Also,there's a world of difference between feeding in the torque reasonably gently,and doing it with a bang....I know a couple of people who've chewed propshafts doing that,but to be fair,most of these issues are on modified cars.
  23. turbonutz
    turbonutz Active Member
    421
    61
    just buy an evo 10 then? :p
  24. RedDejavu
    1,806
    337
    or S3 with the S-tronic gearbox:D
