Best way to fit coilovers without undoing the dreaded bolt
vr6gordy Oct 4, 2013
  1. vr6gordy
    vr6gordy Well-Known Member
    2,826
    191
    Gonna fit the front coilovers on Saturday but don't want to undo the dreaded bolt ..last time I swoped the springs I took the hub nut off and the drive shaft and removed the hole unit but I found another way by undoing the top wish bone arms and removing the strut that way but witch is easyiest ????
  2. Ollie-B
    Ollie-B Rockin' Shnit
    328
    Perservere amd take the pinch bolt out and replace it and copperslip it to make things easyer in the future, its not as hard to remove as evryone says, both of mine snapped and i had them both out in an hour with a punch and a hammer and some wd40
  3. vr6gordy
    2,826
    191
    havent got time to do it that way ...
  4. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    132
    Dont copper slip the bolt. use grease the copper slip against the alluminium and steel of the bolt will help it corrode
  5. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    3,988
    756
    I use copper slip on my pinch bolts, but then again I change them every year when I service the car, takes a couple of minutes each side. only option is to remove the bolt on the bottom arm going into the subframe.
  6. vr6gordy
    2,826
    191
    sure i said i havent got time to undo the bolt ..so why are people still telling me ???????????
  7. B5NUT
    3,988
    756
    I said undo the bolt on the bottom arm going into the subframe!!!!
  8. ricostuart
    ricostuart Active Member
    409
    43
    tbh if you dont have "time" to do the bolt, then I would strongly advise waiting until you do have time so you can do the job properly. If you do it wrong, it could have some serious consequences! Failing that, take it to a shop to get them to do it properly. Dont try and cut corners.
  9. vr6gordy
    2,826
    191
    How will this let you drop the spring and strut out when it's still bolted to the up right ???
  10. Ollie-B
    328
    3 bolts under the bonnet, 1pinch bolt, 1bolt in the bottom of the strut
  11. vr6gordy
    2,826
    191
    Was meaning the way b5nut said
  12. Stu-pid
    Stu-pid Member
    84
    I fitted a set on a b5.5 passat without removing the pinch not sure if it the same process. But I compressed the spring in place and that gave me enough room to undo the top arms. It's awkward to get the strut out but saves messing about. There's a guide for it somewhere I just can't find it
  13. Stu-pid
    Stu-pid Member
    84
  14. vr6gordy
    2,826
    191
    What way won't work on a b6 cos there's only 1 bolt that holds the strut so you have to lower the hole unit
