Best way to find out power gains?
McGart Jul 23, 2009
  1. McGart
    McGart Member
    35
    Whats the best way to find out my actual power gains on my audi s3 which i bought just over a year ago. I asume i have to take car to a specialists etc, is this costly?. And where do i start looking. Live not far outside glasgow.
    I have been told car has
    REVO remap, taking it to 265 bhp
    And it also has a BMC carbon filter and a forge recirculating alloy dump valve.
    Any help is well appreciated
  2. LiveWire
    LiveWire S3X
    329
    The only way you will find out the true BHP of your car is to get it on a rolling road...and get a print out of the power your car is producing.
  3. IIIadidasboy
    IIIadidasboy Member
    312
    Rolling Road is the obvious answer.
    But you can also do it via VAG-COM - if you have access to it - by logging certain blocks and then transferring to MS Excel. There are spreadsheets available on the web that are already set-up to do this, think it's called "butt dyno" or something. Some say it's more realistic / accurate, because you're doing the runs with correct air flows etc - but you'll need a very long and quiet road to do it - remember, stay safe!!
  4. S3fan
    S3fan Kiteyboy
    372
  5. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,150
    1,986
  6. McGart
    McGart Member
    35
    much would it cost to have car tested on rolling road
  7. McGart
    McGart Member
    35
    any rolling road in glasgow for s3 quatro?
  8. 1animal1
    9,978
    Vagcom works it out from various signals from various sensors..... personally id be finding a specific type of rollers (cant rem the name of them) as a lot of rollers really dont tell the full story..... throw in your haldex and your left with an even bigger problem to identify the power
    no help im afraid, we're all in the same boat
  9. Andrew@A.L.D
    3,877
    617
    To get a true reading then you need a engine dyno
    Rolling roads are not the most accurate when it comes to true figures
  10. 1animal1
    9,978
    knew someone more experienced would pop up, cheers Andy :)
  11. Andrew@A.L.D
    3,877
    617
  12. S3KO4
    S3KO4 Member
    850
    doubt 265. I have stage 2 with all the mods, and only getting 263
  13. Chlippo
    Chlippo Member
    679
    15
    u still need the FMIC mate
  14. 5teve L
    5teve L Member
    152
    All RR differ, some over read, some are pretty much spot on (which usually leave the owners upset)
    What I used to do was to get a RR figure before I start modding & during so then I can see what difference the mods have made. A RR can give you a rough idea, it really does depend though. I think some RR will have to pull the Haldex fuse to do the runs...
    I think Thor have a better way of doing things with hub dyno's but as said above, bench dyno is the only way to get a true figure without fudge factors.
