Best way to cut back of glovebox to fit Phatnoise?
Roswell Nov 6, 2005
  1. Roswell
    Roswell Member
    312
    As subject really.
    Do I have to remove the whole glovebox or can I cut it from the front?
  2. A6QuattroDriver
    A6QuattroDriver Member
    93
    Glove Box should come out simply by removing 5 bolts - certainly did on my A4 which I've been playing with this afternoon.
    Would recommend removing it as it'll make it easier and safer to work on - you'll end up with a better job I reckon and probably let holes in your hands.
    Good luck
  3. scoTTy
    scoTTy Active Member
    1,962
    Came out easy on my TT and S4 so I don't see why the A3 should be different.
  4. Banwell
    Banwell previously LeeS3
    393
    you might want to mod the phatbox to fit the glove box. Ie remove it from its metal housing.
  5. The911SC
    The911SC Active Member
    1,032
    I would put it in the boot where nature intended!.. New glovebox is about £130 and there is not much room behind it on the A3.
    Personal choice though..
  6. Banwell
    393
  7. Roswell
    Roswell Member
    312
    [ QUOTE ]
    [/ QUOTE ]
    Yeah, I've taken the big aluminium looking bit off but where the glovebox slopes down at the back there isn't enough room to fit what's left of the Phatnoise in!!
    Is your Glovebox cut at the back Lees3?
  8. The911SC
    1,032
    I dont think that is his install unless he drives a LHD?..
  9. The ones I have done are on the RH side of the GB, drop the GB and cut the back out the same size as the phatbox.
    The phatbox site slighty proud, but the door closes perfectly
    Craig
  10. Roswell
    Roswell Member
    312
    Cool...thanks again craigyb!!
  11. gizze
    gizze Member
    645
    [ QUOTE ]
    [/ QUOTE ]
    Is that a beige head unit?!! /ubbthreads/images/graemlins/smile.gif
