Best way of disc between brake disc and alloy
theo289 Aug 20, 2013
  1. theo289
    theo289 Member
    293
    Hi All,
    Probably one of the most vague posts here but i have a little bit of surface rust which i wish to remove between the brake disc and the alloy wheel. i've tried Iron Out and its removed a little bit of it but i'm looking for that little more va va voom with removing the surface rust - WD40? Brake cleaner? Surface cleaner? Cilit Bang?! (obviously wouldn't put cilit bang on them)
    Appriciate the help
  2. RobbieWebs
    RobbieWebs Well-Known Member VCDS Map User
    1,031
    249
    Vague isn't the word lol.
    Take a pic and post it m8 :)
    Is it around the brake disc on the outside ur on about?
    Or the wheel?
    Iron out is for metal filings and contaminates, not for derusting :)
  3. theo289
    theo289 Member
    293
    i did try my best! it is the little drum between the brake disc and the inisde of the alloy wheel - usually they get quite bad surface rust.
    will get a picture and upload it :)
  4. theo289
    theo289 Member
    293
    After cleaning the same as what this guy here is spraying
  5. RobbieWebs
    1,031
    249
    I might be wrong but I'm sure u can rub it down with sandpaper/ wire brush and paint it.
    I'd be carefull and mask off threads etc before doing it tho :)
  6. RobbieWebs
    1,031
    249
    fanta likes this.
