best upgraded throttle body?
09jaket Apr 18, 2012
  1. 09jaket
    09jaket New Member
    27
    hi, ive got a a3 8l 1.6L, what would be the best bigger throttle body to fit?
    if your going to say its not worth it dont reply, im just asking as its something that im going to do i just need to know which TB will fit
  2. <tuffty/>
    21,964
    4,233
    There isn't one mate sorry... I won't say its not worth it (it isn't... damn!! said it...!) but there isn't such a thing that will make any difference to you car..
    The std throttle body is about as good as it it gets unless of course you want to try throttle bodies but then you would probably need a standalone ECU and other mods to get the best out of it...
    The 1.6 engine in these cars isn't really that tunable mate... sorry..
  3. Andrew@A.L.D
    3,879
    617
    If its not worth it and not going to gain anything from it then its a total waste of your money which is true in your case unless you have already do a load of other modifications
    What have you done to your engine already? You can spend money else where and gain more from other modifications before you do anything with throttle body modifications
  4. Broken Byzan
    13,244
    468
    you will get far with thiat attitude, fair play... LOL
    If you have enough money anything is possible, but seeing on the 1.8t std throttle body is capable of flowing about 200BHP over std, lets assume you won't double the whole 105 you currently have. there really is no point.
    /end
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Its not w_rth it....
    get yourself some nice rims?
  6. 09jaket
    09jaket New Member
    27
    ive polished the head, valves, ported, polished ports, full milltek exhaust, hi flow race cat, sard injectors, higher pressure fuel pump, kent cam 270, new cam followers, lightened pulley, diamond racing clutch and lightened flywheel.
  7. 09jaket
    09jaket New Member
    27
    already got a set of dotz mugello 17's
  8. 09jaket
    09jaket New Member
    27
    is there any difference in size of the 1.6 throttle body and the 1.8? :/
  9. Andrew@A.L.D
    3,879
    617
    Who did the head work? Yourself?
    If i was you i would sell the engine and start over as you've done a lot of modification already and you want more so that T/B will not give you the gain you want and is a waste of money unless you go ITB ( one for each cylinder ) But thats expensive as i've been there and done that in the past with a ex project
  10. s3dave
    10,110
    736
    :sign_pics:
  11. Sam_
    Sam_ Down under
    3,039
    483
    I heard the S3 throttle body, along with the rest of the engine, is a good upgrade for the 1.6 :)
    Benjiman46 likes this.
  12. 09jaket
    09jaket New Member
    27
    head were ported by a local machine shop, got a good deal as i know the bloke, done all the polishing myself, alot of effort but worth it, i was thinking of buying the 8l s3 lump? would that go in? :s and building it from the ground up again to exactly how i want, was quoted £850 by a local garage to put it in if i supplied all the bits and they would have it done in a day.
  13. 09jaket
    09jaket New Member
    27
    how do i get a picture on here?
  14. s3dave
    10,110
    736
  15. 09jaket
    09jaket New Member
    27
    just set a pic as my profile picture, dont know if you can look at them?
  16. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    78
    What bhp are you hoping to achieve? I would class a standard 1.8t sport 150bhp to be on the slow side.
  17. 09jaket
    09jaket New Member
    27
  18. 09jaket
    09jaket New Member
    27
    from the 1.6 or a 1.8t conversion?
  19. camscockle20vT
    1,740
    78
    From the 1.6.
  20. Andrew@A.L.D
    3,879
    617
    A machine shop ported it and you polished it
    Please god I hope you didnt polish the inlet ports!
  21. badger5
    9,637
    2,073
    is this a pi$$ take thread or serious one..
    I cant tell
    krisrg87 likes this.
  22. badger5
    9,637
    2,073
    1.8t is 60mm
    measure yours
  23. 09jaket
    09jaket New Member
    27
    only removed the sharp edges from the casting marks on the inlet ports
  24. 09jaket
    09jaket New Member
    27
    i will have to measure it tomorrow, will the fitment still be the same?
  25. Andrew@A.L.D
    3,879
    617
    So what parts did you polish then
  26. 09jaket
    09jaket New Member
    27
    polished exhaust ports, cleaned up inlet and removed any sharp edges and rough surfaces, polished the piston heads/sleeves, polished the valves to a mirror finish, was thinking about polishing the inlet ports properly but dont know what the effects would be? :/
  27. Sam_
    Sam_ Down under
    3,039
    483
    No offense but I think the term "******* into the wind" is applicable here. Honestly, focus your efforts elsewhere. Chasing 1 or 2 bhp with a shedload of time just isn't worth it.
  28. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
    Good old Aussies tellin it like it is ;) love it lol
  29. Benjiman46
    551
    24
    On a serious note though if you really are serious, then either save your money and 1.8t it... Or 3.2 V6 it... Or if you're adamant you want to stay with the 1.6, get some aftermarket throttle bodies and an Omex or Mega squirt stand alone management system.
    Or just fit a 300 shot of NOS as you seem very F&F ;)
  30. Sam_
    Sam_ Down under
    3,039
    483
    "A stand alone fuel management system, not a bad way to spend $10,000"
    I totally understand wanting to do work on the 1.6, insurance possibly being a big one but I'd still wait and save your money and get a 3.2 or 1.8T as said above. Even better, leave it in the shell it's in and modify it there if need be. For god sake don't polish your inlet ports, try some mr sheen on your sideboard instead.
  31. Andrew@A.L.D
    3,879
    617
    Lots of mistakes with polishing of part
    I would like to know who told you to polish the things you did?
  32. Benjiman46
    551
    24
    "It's an amazing machine..."
  33. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    lol. Sorry, but I have to agree here. If your TB is 60mm like the A3/S3 one, it's a good flower. I currently push over 300 g/s air flow through mine - no problem.
  34. Gops
    3,198
    666
    "it has a cool air intake, a NOS fogger system Dominic... It has direct port nitrous injection..
    Yeah yeah and a standalone fuel management system.. Not a bad way of spending $10,000!"
    On a serious note, youve got the right heart into spending money and time on your engine, I give you credit to that, but on the wrong engine. Get hold of a 1.8t engine and go nuts with all the info here, you'll have a right rocket if you spend the money and time on the right things. If you don't wanna spend too much money then buy a 1.8t and work from there (prob easier but if your anything like me and can do with a lil project then buy an engine)
  35. <tuffty/>
    21,964
    4,233
    To be fair... if you are doing all this work yourself and not paying the sorta money it would cost getting 'AN Other' to do it then fair play... I used to do the same back in my Mk2 Escort days... built a 2.1 pinto and ported the head etc, fitted twin 45's and cams etc... granted in those days that is what tuning was all about...
    We will always get the '1.6' tuning questions on 8L as its the nature of the beast with young people and insurance etc... but if you are willing and able to faff like the OP then I can't see why not...
    I was even thinking of putting a K03 on the 1.3ltr 8v in my Mk2 Golf... because I can :)
