best spark plugs for 2.0 fsi...
marcuswomersley Nov 20, 2011
  1. marcuswomersley
    marcuswomersley Member
    What are the best spark plugs for the 2.0 fsi engine? I know fsi engines are fussy on the manufacturer/model of spark plugs they have, so can anyone give me any advice? thanks
  2. marcuswomersley
    Anyone?
  3. quattro tony
    quattro tony Member
    167
    Best plugs imho are o.e std plugs. They were chosen by audi to be the best suited plug for your engine. Bosch or ngk are most known types. Are you looking to upgrade them? The only obes ive used are denso iridium, expensive but seemed to be a good plug.
  4. marcuswomersley
    The ones i've got in at the moment look a bit worn, so I was just wondering if there is any upgrades, and Ihave a miss fire at low rpm, and wondered if the spark plugs could be causing this.
  5. DAZ1985
    DAZ1985 Member
    124
    Not a great believer in upgraded plugs meself
    Standard plugs more than upto the job
  6. jlawie
    jlawie Member
    Anyone able to tell me what the standard plugs are for this engine???
    Thanks!
  7. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,483
    I've always found NGK's to offer most consistent result. As it's in the B6 forum and the first car mentioned is a 2.0FSi, I'm 'assuming' your car is a 130bhp model and manufactured some time between 2000-2005. If not then these part numbers are not right.
    OEM Part: BKUR5ET
    Iridium Part: BKR5EIX
    Iridium tipped plugs have harder tips, so in motorsport applications they last longer. I used them for about 4 years with mixed results, and have returned to the standard platinum electrode plugs as they seem to foul less in the FSi engines, especially when modified. Also NGK say they conduct better than the Iridiums which as built for endurance rather than outright smooth running.
    If these aren't the right ones, suggest you look at this website that helps you choose step by step: NGK Partfinder Catalogues
  8. jlawie
    jlawie Member
    Mines actually a 2.0FSi AXW A3 150bhp
    Cheers for the info! I'll check out the link mate
  9. kopn
    kopn New Member
    10
    Hello!
    NGK 6458 spark plugs are better than original NGK 7742 for my 2.0 FSI BVY. NGK 6458 do not give misfires at -10C in 10 seconds after startup. The power increases faster with accelerator pedal push. However, 2.0 FSI BVY pulls with jerks without accelerator pedal push on gear 4. What do you think?
  10. kopn
    kopn New Member
    10
    I meant above that 2.0 FSI BVY pulls without step on the gas even on 4th gear with original spark plugs VAG 101905620 Long Life (NGK 7742).
    With NGK 6458, 2.0 FSI BVY pulls with jerks forward-backward without step on the gas even on 4th gear. This in the only disadvantage of NGK 6458. The fuel consumption is lower with NGK 6458.
    Why is fuel consumption is 0.8L/hour on neutral gear and 0.9L/h on the first gear with the clutch pedal fully depressed (in my Passat B6 with 2.0 FSI BVY)?
  11. QuattroCalum
    QuattroCalum Active Member
    533
    108
    43
    Might not be the spark plugs, have a look at this video it shows a 2.0 tfsi inlet manifold (albeit on a golf) this is the downside of direct injection unless you use a catch can.Where in the rev range does it missfire?
  12. kopn
    kopn New Member
    10
    What is the catch can?
    passat B6 2.0 FSI BVY 6-SPEED-MECHANICAL 87 T.KM 2007 Highline
  13. kopn
    kopn New Member
    10
    Hello!
    The VAG 101905620 Long Life (NGK 7742) spark plug has two side mass contacts, which are further from the power contact than the central mass contact. It looks like the spark never goes from the power contact to the two side mass contacts, it goes to the central mass contact always. The side contacts are completely black from carbon fouling in my VAG 101905620 spark plugs. Moreover, the side contacts screen the fuel from the power contact. This leads to misfires at startup at -15C. Bosch 0 242 235 775 "Double platinum" spark plug is a replacement for VAG 101905620. It does not have the two side contacts. Others write that Bosch 0 242 235 775 has less misfires at startup at -15C.
    Why did VAG make the two side contacts at all? It looks like the design is just stupid.
    Who has compared Bosch 0 242 235 775 and VAG 101905620 in action in 2.0 FSI?
  14. QuattroCalum
    533
    108
    43
    Something like this http://www.ebay.co.uk/itm/Oil-Catch...hash=item4cfdc110c5:m:mmXi6NjGWaVZVCc-qrfV6cA placed at a strategic point in the positive crankcase ventilation system. This will catch any oily residues and keep the inlet manifold/ inlet valves cleaner for longer, as you can see in the link it can make a fair old mess in there.
    kopn likes this.
  15. kopn
    kopn New Member
    10
    What video do you refer? There is no link in this topic.
  16. kopn
    kopn New Member
    10
    Mecanics say that EGR is the biggest source of pollution of the engine. EGR adds exhausts to the intake air.
  17. QuattroCalum
    533
    108
    43
    Sorry I forgot to add the link, it's for the 2.0 tfsi but the problem is the same, here it is,
    kopn likes this.
  18. QuattroCalum
    533
    108
    43
    What do you think the exhaust fumes stick to? Oil vapour.
  19. kopn
    kopn New Member
    10
    Thanks for your suggestion!
    Can Direkt Injection Reiniger http://www.liqui-moly.de/liquimoly/...nDocument&land=GB&voilalang=e&voiladb=web.nsf remove the fair old mess in there?
    If the filter removes the oil, then it consumes the oil. Will it lead to higher oil consumption?
  20. QuattroCalum
    533
    108
    43
    The best way to clean it is the same way as in the link I posted, regarding the oil consumption, this should not change as the oil caught in the can would be the same amount that would have gone into the inlet manifold.
  21. kopn
    kopn New Member
    10
    Thanks for your view!
    I'm afraid to allow our mechanics to dismantle my engine to clean. They may not assemble in the same quality. What is the best fuel additive to remove the mess?
  22. QuattroCalum
    533
    108
    43
    The fuel is injected directly into the combustion chamber or cylinder if you like, no amount of fuel additive will help as it doesn't enter the intake manifold at all, that's why it has to be taken apart.
    kopn likes this.
  23. kopn
    kopn New Member
    10
    Why are the denso iidium good? What is good about them exactly?
    passat B6 2.0 FSI BVY. 6-SPEED-MECHANICAL G0K. 87 T.KM 2007 Highline
  24. kopn
    kopn New Member
    10
    Mine is VAG 2.0 FSI BVY 150HP. Are not the spark plugs in your message suitable?
  25. Bradderz_1988
    3,945
    235
    Adding WMI to direct port petrol engines can aid in the reduction of carbon build up in the inlet, best to clean then fit a WMI kit.
