Best place to source new style Sportback rear lights?
maars Sep 20, 2010
  1. maars
    maars Full speed ahead
    576
    Other than negotiating a discount with an Audi dealer, where should I look for a great deal on a set of 2010 SB rear lights? Kufatec perhaps? I've not seen any appearing on ebay UK recently.
  2. sub39h
    sub39h Active Member
    2,502
    there's a german eBay seller called tuning fanatics shop. try there. the sportback lights aren't LHD or RHD specific.
    alternatively try TPS
  3. fizz
    fizz Member
    264
    Stoke Audi were the cheapest for me.
  4. Swanny356
    Swanny356 Active Member Audi A5 Audi A1
    369
    78
    How much should these cost and how difficult are they to change?
  5. maars
    576
    They're coming out around £200 via ebay.de.
    I was hoping there might be a replacement for VagParts?
    And they're pretty straightforward to fit - having had to take one of my lights off over the weekend to change a bulb. Putting the outer cluster back requires some unwanted brute force to get the clips to seat properly.
  6. bmcg
    bmcg New Member
    tps have got these lights for around £200 inc vat.as far as i know they're plug and play.
  7. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    They are not plug and play fellas.
    You will need coding changes and also rewiring or a new adapter harness.
  8. c_w
    c_w Well-Known Member
    1,169
    91
    Can any expand on the "coding" changes in VAGCOM with the new style rear lights? I've read a few threads on this and other forums about "you then need to code it in VAGCOM" but what do you have to change from and to? :)
  9. c_w
    1,169
    91
    To answer my own question, the coding is;
    Byte 9 to Dec = 0 - as the final brake light
    Byte 10 to Dec = 0 - fog lamp as a taillight
    Byte 12 to Dec = 36 - dimming rear stand light (the figure 36 seems to be from a range of 22 to 100 for brightness)
    Byte 19 Bit to cold diagnosis rear active - this must be activated (usually already activated)
    One further question, on the US forums their Sportback's have 6 brake light bulbs light up (the two in the outer lamps and the 1 (also a fog light) in the inner tailgate lamps, I think this looks better but I think even 09 UK Sportbacks only hae the outer 2 brake light bulbs light up under braking. Is this something that can be changed via VAGCOM so all 6 bulbs lights up??
  10. NHN
    29,596
    1,782
    Got a better idea than that, use the rings as your tail lights & brake lights, looks immense.
  11. tcardio
    tcardio Well-Known Member
    1,040
    308
    everything lights up in 2009+ models including the amber when braking. needed to rearrange the wiring from facelift to nonfacelift to make it work
  12. c_w
    1,169
    91
    Are you sure as I was following either an 09 or 10 plate and only the outer two brake lights lit up.
    NHN is that a VAGCOM setting? to have the rings as brakelights too?
  13. vw754
    vw754 vorsprung Durch Technik
    2,354
    58
    looks nice that pic does.
  14. NHN
    29,596
    1,782
    No its not a vagcom setting, requires wiring.
    TCardio, expand on your post please cause afaik amber doesnt light up on braking that I've seen unless you mean they flash with hard braking.
  15. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    You can make the fog lights on the boot lid to light when you break, using the vag-com. I did this on my car but I didn't like it. Too bright. I have DSG gearbox and at stops, when I keep the break pedal pressed, the one behind me is blinded.
  16. c_w
    1,169
    91
    How do you do that (so all 6 lights light up) in VAGCOM? (I've looked and tried changing a few settings but nothing changed).
    Is it a LHD vs RHD issue?
    Any more VAGCOM tips gratefully recieved! (Johnny Bravo helpfully gave me the original tail light coding in my second post)
  17. Johnny Bravo
    898
    70
    Yes. All 6 o them. I'll take a look an come back with the answer. I do not remember right now where exactly is the option. Anyway, you only have to check a box.
    I don't think it has something to do with LHD and RHD since the lights will work on both sides.
  18. NHN
    29,596
    1,782
    LC,21,4,Rear Fog Light as Brake Light in module 09.
  19. Johnny Bravo
    898
    70
    Central Electrics - Coding - Long Code Helper - Byte 21 - Bit 4 has to be checked
  20. NHN
    29,596
    1,782
    There's an echo in here.
  21. Johnny Bravo
    898
    70
    Ohhh.. didn't noticed your answer.
  22. c_w
    1,169
    91
    Ok thanks to both of you! Will check this tonight although I seem to remember going through the whole module looking for something that might do it - "rear fog as brake light" sounds rather obvious but I must have missed this!
  23. NHN
    29,596
    1,782
    Just remember your CE module must support 21 bytes to be able to code this.
  24. c_w
    1,169
    91
    Yep (it has xenons fitted). Just been out and changed it now and got full brake lights! Can't believe I missed that! - I thought I'd gone through the whole long code before.
  25. vw754
    2,354
    58
    is it more brighter than the normal brakelights on the car? and how does the fog light function work now?
  26. c_w
    1,169
    91
    Basically all "6" brakelight bulbs light up (3 perside, one in inner lamp and two in the outer lamps). When you have the fog lights on the inner brake lights become "inactive" because the fogs are already on.
    They do look very bright but I think it's a combination of 6 25w bulbs coming on but also the new style tail lights are just more reflective I think so just perform better. The bulbs are still standard 25w filament bulbs. It looks better with all 6 brake lights as it fills the tail lights fully (as in the photo further back in the thread) like on the new a4/a5s.
  27. Johnny Bravo
    898
    70
    Too bright in my opinion. I wouldn't like to be behind someone at a stop who has this thing done.
  28. c_w
    1,169
    91
    Tail and brake lights are getting brighter these days (despite using same traditional bulbs in this case), probably in the interests of "safety". However those with autos who use footbrakes at lights etc it's a bit of a problem, but always has been!
    I like the brake lights filling up the tail light rings completely much like the A4/A5 LED tail lights do.
