Best place to buy forge gear from ?
Timmsyh Aug 31, 2013
  1. Timmsyh
    Timmsyh Member
    32
    Hi Iam sure there is a thread about this already but I've had a look and I can't find it
    also has anyone changed an agu 1998 to 6 speed (new box ) is there a way of doing it ?
    Thank you
  2. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Why on earth would you ever want to swap from 02j to 02m?
    Just fit a facelift 02j gear linkage and all your woes will be gone.
  3. Timmsyh
    Timmsyh Member
    32
    Just want one more gear :)
  4. Sam_
    Sam_ Down under
    3,035
    480
    Oddly, I'd have to agree with Jardo. I'm buying a decent clutch and flywheel at the moment and already got a wavetrac diff, both parts are way more expensive for an 02M compared to the others. Not worth it to say you have a six speed.
  5. 16Klappe
    5,795
    1,183
    The over all final ratios are as good as the same, but having the wider spread in the 5 speed lends itself to the torque of our cars.
    An 02M will basically make your car slower and cost more.
    Why do you want an extra gear?
  6. Timmsyh
    Timmsyh Member
    32
    Okay sweet , just a cruising gear at like 80 for better ratio
    also I brought my Audi with clutch gone so I repaired the clutch (standard one) and the left front wheel had negative camber so I changed the front bed out of my 2001 Audi and replaced steering rack as my track rod end was bent and fitted coil overs (eBay ones) and it has improved the camber alot but there is still a tiny bit there any ideas what it could be . Has anyone heard of the hubs bending ?
