Best place for a remap by a mile
liquids3 Mar 12, 2012
  1. Alais DJA
    Alais DJA Member
    559
    50
    Rs6 turbine and compressor :)......
  2. <tuffty/>
    21,951
    4,228
    2283 is an 8P S3 billet comp...
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    is the 2286 the r6 comp?
  4. <tuffty/>
    21,951
    4,228
    2280 rings a bell....
  5. liquids3
    liquids3 Member
    930
    22
    Yea im not driving it,at least the turbo mani are on now that was the main bit,just rang forge for fmic,because i get dicount,will be sorted end of month
  6. liquids3
    liquids3 Member
    930
    22
    Sorry do you know a ruff price on these?
  7. badger5
    9,633
    2,071
    budget on £50/injector+vat
  8. Prawn
    11,711
    3,714
    I don't mean to be rude here, but discount aside, I bet you're still paying more than the total cost of a Toyosports setup, and you'll get a product that doesn't work as well.....
    You'd have to be getting well over 50% off to make the costs comparable, and even then the forge cooler isn't really man enough.
    I think you're making a mistake there dude....
  9. <tuffty/>
    21,951
    4,228
    I concur and have already said as much earlier in this thread... I don't believe this size of FMIC to be suitable for a hybrid... and that based on personal experience rather than conjecture
  10. liquids3
    liquids3 Member
    930
    22
    Im on a learning curve with this sort of thing,the discount i will get at forge will make the price near bang on the same ,and do appresiate all help!,i just don't want to loose lower grill's ect,but if the performance is that different toyosport cooler it is,just don't want to compramise looks!,advise taken though thanks for help.
  11. liquids3
    liquids3 Member
    930
    22
  12. <tuffty/>
    21,951
    4,228
    I fairness I think the Forge uses more rows than the AH V1 which could mean flow wise the Forge should cope better but it still has 51mm inlets which is a compromise as I know 63mm bends can be welded on in place...
  13. liquids3
    liquids3 Member
    930
    22
    So a modified forge cooler might flow better?,i know a few people that work there,might be able to get them to modify it rather than re fabricate it somewhere else.
  14. liquids3
    liquids3 Member
    930
    22
    Just for the fact like i said above want it hidden,not trying to be awkward
  15. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    Im sure a few people have managed to fit a welly cooler without having it on display well?
    I think its a case of mounting the cooler as far back as possible and routing the pipes in a tidy way.
    easier said than done though
  16. <tuffty/>
    21,951
    4,228
  17. Alais DJA
    Alais DJA Member
    559
    50
    #Wellycooler
  18. liquids3
    liquids3 Member
    930
    22
    Try and fit wellycooler as far back as pos then,ryan mtm has fitted before,il speak to him and get some tips on how his went!thanks!
  19. aragorn
    18,661
    877
    I'm sure someone on here mounted a big welly style cooler upside down?
    With the pipes dropping down from the top?
  20. Broken Byzan
    13,244
    468
    Bill did it to Lee's BT car
  21. <tuffty/>
    21,951
    4,228
  22. liquids3
    liquids3 Member
    930
    22
    That looks more like it!,is there a build thread pipes used?
  23. liquids3
    liquids3 Member
    930
    22
    I can see the link now its ok!
  24. badger5
    9,633
    2,071
    63mm 90' bends welded onto the toyo core
  25. superkarl
    superkarl MAN OF STEEL
    9,622
    2,487
    how did you weld 63mm into a 76mm hole?
    i was looking at getting a stepped alloy reducer
  26. badger5
    9,633
    2,071
    "magic"
  27. superkarl
    9,622
    2,487
    please :(
  28. badger5
    9,633
    2,071
    please what dude?
    I dont follow, sorry
  29. Prawn
    11,711
    3,714
    I think karl wants to know how you managed to cut off a 76mm pipe and weld in a 63mm one.
    I'd imagine it's just clever welding isn't it? 76mm OD pipe cut off should leave a 74mm hole, which leaves a 5mm gap all round to bridge? Or flare the end of teh 63mm pipe to suit.
  30. badger5
    9,633
    2,071
    its cut on the slant.. the 63mm bit, so aligned top and bottom, and a little tap on the sidetanks moved them in a little, and the rest was some welding magic :)
  31. superkarl
    9,622
    2,487
    cheers bill :icon_thumright:
    just hope my welder is as magic as you
