best parts to buy for high hp engine
bansheeboyo May 24, 2009
  1. bansheeboyo
    bansheeboyo Member
    201
    hi guys
    got a spare engine in my shed and am thinking of buildin a big power motor
    cams ,porting,pistons,valves,flywheel,manifold,clutch what do you guys recomend ?????
    i was smoked by the new fiesta st or rs
    cheers scott
  2. bansheeboyo
    bansheeboyo Member
    201
    i have a 1.8t a3 quattro with a k04 turbo
    incase that makes a diffrence to anything
  3. S3APY
    S3APY Member
    127
    Gas...
  4. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,192
    2,011
  5. 1animal1
    9,978
    you got smoked by a fiesta ST??? what on earth are you driving????
  6. alijames
    alijames Active Member
    1,024
    Miss Daisy?
    You are as subtle as ever Tim!
    Cheers,
  7. kaizokuninja
    kaizokuninja Member
    145
    surely if he's running a k04 turbo the ST should have no chance and it should be high 200 or low 300 anyway?
  8. 666markyboy
    666markyboy Well-Known Member
    1,211
    49
    Have you had the motor remmaped to take advantage of the K04 turbo ??? you should be seeing S3 specs of around 265 BHP
  9. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    I am building a 2.0l 20v stroker that I hope will be capable of over 500ftlbs before it grenades.
    head is the weak part. replace all valves, springs retainers, guide, consider single groove collets if you expect to go over 8000rpm.
    stock cams are fine.
    porting is expensive bang for buck, stock is fine unless you are trying to squeeze that extra 50bhp out of it.
    the stock pistons are fine for high hp unless you want to overbore
    change rods, lots of options with prices from $350 - $1000
    stock crank is fine, cast or otherwise. (see below for main caps)
    get your crank dowelled and fit a new crank sprocket and bolt (this is a major weak point)
    new bearings/seals throughout.
    new oil and water pumps (metal impeller)
    some people use billet main caps but IMO its a bling upgrade based on spec sheet cock measuring. can't find anyone who has blown an engine in a non race environemnt due to caps.
    that said a good set of main studs and head studs are always usefull.
    lots of clutch options depending on power
    Southbend do one of the best clutches for the 1.8t. they also do SM flywheels, which you would probably want
    choose your suppliers and parts well and you could do all that for £1500 -2000 assuming you are doing the labour.
    buy in the US!
  10. bansheeboyo
    bansheeboyo Member
    201
    no havnt had it remapped yet thinking of gettin it pipes and remap
    can u go stage 2 if i get full exhaust system? already have k&n
    do i need to tell mapper about k04 turbo ?
    if i get the stage 2 wht power you recon ill be getting?
    i recon that fiesta was pretty tuned cause it smoked the car it was racing the new focus rs or st not sure wht 1 i was a car behind them at traffic lights seen they were revin engines and thought i would join in
  11. kaizokuninja
    kaizokuninja Member
    145
    You've put a ko4 turbo on without remapping? I wouldnt think you're making much more power from standard if that is the case [though i may stand corrected shortly]...
    You would need to tell the garage doing the remap that you had a different turbo, but you may need to upgrade other bits, ie TIP, DV, intercooler, downpipe, exhaust etc to actually benefit from having the bigger turbo on it.
    Who actually put the turbo on, as if it was a decent garage surely they would've told you that you cant just bolt on a bigger turbo and not uprate anything else and expect to gain that much from it....
