Best oil for high mileage AJL 1.8T?
madkebab Sep 29, 2011
  1. madkebab
    madkebab Member
    421
    I have just bought a 1.8TQS with 145k on the clock. What oil should I be using a fully synthetic or semi synthetic? I used to use Synta silver on my old 1.8T AEB just wanted to check to see if that was still the best bet.
  2. jamie226bhp
    jamie226bhp Member
    468
    I run castrol edge 5w 40 which is full synthetic and changed every 4000 miles
  3. Jason.s
    Jason.s Active Member
    2,879
    348
    Would still use 5w40 quantum from maindealer or TPS
  4. aragorn
    18,490
    855
    Yeh stick with a fully synth oil, and change it regularly.
  5. Oranoco
    Oranoco Well-Known Member
    3,972
    405
    Vegetable but after 150k I would swap to Olive :jester:
  6. Broken Byzan
    13,237
    465
    Full synth on my low mileage 140k TQS here. Just change more regularily than 10k , 6 k max maybe?
    got her then Si?
  7. madkebab
    madkebab Member
    421
    Yes mate. Probably bought with my heart rather than my head as there are a few bits that need sorting. These include
    ABS controller
    Thermostat
    Rear wheel bearing
    Oil service
    Will get some pictures up and the full spec when I get a chance. I can't believe it was 8 years ago I joined this site when I bought my first Audi.
  8. madkebab
    madkebab Member
    421
    well got the oil changed today. Picked up some Quantum Platinum 5W40 from the local VW stealers as the Audi stealer doesnt stock it! Glad I changed the oil immediately as it looked well overdue and they had used a Motorquip filter. The OEM filter was about twice the size. Anyhow pressure came back up instantly and no nasty noisys from the hydraulic tappets so hopefully the engine is free of sludge.
    Next jobs will be the thermostat and rear wheel bearing. Oh and there appears to be some coolant leaking around the oil cooler, is this just the clips going weak over time?
  9. aragorn
    18,490
    855
    keep an eye on the color of the oil. If it starts turning black get it changed and keep doing so until it starts lasting a proper time and staying golden.
  10. AndyC
    AndyC Moderator Staff Member Moderator
    719
    Agree with above.
  11. Kingfisher
    Kingfisher Active Member
    283
    51
    You sure it's the rear wheel bearing?
    I thought this on wife's 80k miles, specialist looked at it and said no..... but the rear lower wishbone bushes were worn, reckon that it needed new and then the noise would go ( also odd wear pattern on tyres).
    Well, had new tyres ( bought Goodyear assymetric2 this time) and immediately the rumbling has stopped . So it's about to get new bushes and an alignment.
    Same with the cooler and traces of coolant ( sort of pinkish ), keeping an eye on it but the oil is fine and I think it's just a slight weep from the hose/clips. It's been like this for several yaers but no real loss of coolant.
    By the way apparently there is an even bigger filter that fits , think it is from the 2.5TDi vans?? 074 115 561 is the part number, must hols at least anothe half a liter of oil !
  12. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    awhh come on... surely such a star of engineering deserves extra virgin ?:icon_thumright:
